Go to Post The imbalance and vibration is telling you something, you are not listening. - Al Skierkiewicz [more]
Unread 12-04-2006, 02:27
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Combining camera + encoder code
Hey all!
I took the camera.c, camera.h, tracking.h, etc.. and put it right into the encoder code that kevin watson designed earlier in the year. I did some slight modification to the code so that the camera doesn't use the servos to move, it uses the drive train to move around. I tested all the code in the normal camera version of the code, and it works flawlessly.
Now when I took the encoder version of the code and combined it with all the files that Kevin Watson specified to include in the code written in camera_readme.txt, serial_ports_readme.txt, and tracking_readme.txt. I have everything the readme ask for. The code builds, the encoders work, but the camera says that there is No Camera Found!!!!!!!
Any ideas!??!?!
Thanks!
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 12-04-2006, 05:41
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Combining camera + encoder code
are you handling the camera interrupts in user_routines_fast.c?
Robot Inspector
Unread 12-04-2006, 18:48
kiettyyyy's Avatar
Yes I am .. Could it be that I called the get or put data after the startup of the serial ports? Who knows.. Ill try some other stuff at the practice field today.. talk to yall soon
-Kiet Chau
www.team1538.com
Unread 12-04-2006, 20:33
The encoder version of serial_ports.c sets serial port 2 (the TTL serial port) to 9600 bps while the camera version sets it to 115200.
Which one are you using? It should be the one from the camera.
Unread 13-04-2006, 00:53
kiettyyyy's Avatar
Oh! Yeah i just found SPBRG2 = BAUD_9600; // baud rate generator register [251]
Was that what you meant?
[edit]
Yep i found it inside the code now.. Ill replace it and test all of it tomorrow
Thanks everyone!
[/edit]
-Kiet Chau
www.team1538.com
Unread 13-04-2006, 09:39
[edit]
Thanks everyone!
[/edit]
Make sure you change the line after it also to TXSTA1bits.BRGH = 1;
Or just copy the entire file from the camera project.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Combining ADC, Serial, and Camera_s codes kaszeta Programming 6 22-01-2006 20:23
Camera Code Fishdude404 Programming 1 25-01-2005 18:59
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
