Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Unread 27-02-2006, 08:34
AKA: Brad
#0190 ( Gompei and the Herd)
Re: EasyC autonomous modes
All I can say is too cool, too elegant, and too late at night.
Thanks for fixing the example.
Brad Miller
Robotics Resource Center
Unread 09-03-2006, 15:15
JJMax7 JJMax7 is offline
None #0918 (Circuit Chargers)
Team Role: Driver
JJMax7 is an unknown quantity at this point
Send a message via AIM to JJMax7
Can't you also just put a couple of switches right on the robot using the digital in ports. That way they can be read right at the begining of autonomous mode. Rather than risking getting stuck. This is what my team plans on doing. Hopefully it won't have too many bugs to have to deal with.
Unread 09-03-2006, 17:03
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
That should also be fine JJ- I prefer having the auton. mode set at the OI, but either way will work, provided the code is properly written.
www.metalmoose.com
Unread 09-03-2006, 19:00
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
To keep it simple, and use only one port, we use a radio shack 6 position switch, with 5 resistors as dividers connected to an analog input on the RC.
Unread 06-04-2006, 12:09
Jack-Of-All-Trades
Hmm. I attempted to use the code on the first page, after all the bugs were worked out and all, and it wont display to my userbyte on the OI- any ideas?
www.metalmoose.com
Unread 06-04-2006, 17:43
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Well my final version worked ok so here it is:
while ( !IsEnabled() )
            p4_trig = GetOIDInput ( 4 , 1 ) ;
            if ( p4_trig )
                  if ( autoProgram < 8 )
                        autoProgram ++ ;
                  else
                        autoProgram = 0 ;
                  while ( p4_trig )
            SetUserDisplay ( autoProgram ) ;
Uh, just to ask a dumb question: Did you switch the OI to u-mode? I'm sure you did, just checking though. Also make sure the variable "autoProgram" is set as a global unsigned char.
Unread 07-04-2006, 13:19
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
IS the OI set in the correct mode. Eg when you get set to user mode it should
first display u012 then u000 until you chage modes.
Unread 09-04-2006, 11:24
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
When configuring globals to be either on or off (i.e. only two conditions) such as the "isEnabled" global mentioned above. You might want to instead use a
#define ISENABLED 1 // instead of defining a global
//later in the program put
#ifdef ISENABLED
//put autonomous code here
#endif
This page is a good tutorial on using MACROS, http://vergil.chemistry.gatech.edu/r...al/basic2.html
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 09-04-2006, 13:13
AKA: Dan
#ifdef ISENABLED
#endif
Pretty good advice if not using EasyC, which is what this discussion is about.
Unread 12-04-2006, 01:06
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
I believe that all your creative solutions using !IsEnabled() are actually moot.
Input from the competition port overrides code loops. In other words, even if you have a while(1) in your autonomous code, when your dongle (or whoever's running the match) switches off autonomous, your code drops whatever it's doing, and the Operator Control code starts.
Our code has a while(1) in Autonomous() and it works fine. I can't remember if I've tried it in Initialize(), but I have every reason to think it should work the same. Still, test it with a dongle, just to be triple sure.
On the other hand, the simple way (the way I used) is to have a switch (or several, or an analog input as described above), set it before you power on the bot, and just read it once (no loops).
Unread 12-04-2006, 22:53
Jack-Of-All-Trades
The advantage to this is that it allows us to use the pre-existing joystick; something I much prefer. I got this working on last years robot, so it should be fine; no reason to mess with the safety measures in place- redundancy is my friend. I'd rather have something I know that I wrote backing it up than mystical field-happenings.
Thanks for the info, nonetheless.
www.metalmoose.com
White Paper Discuss: C Programming and Autonomous Modes for Newbies cbolin Extra Discussion 3 09-01-2008 19:32
Rookie autonomous modes StephLee General Forum 6 30-04-2005 13:16
Question about switching autonomous modes DemonYawgmoth Programming 2 23-03-2005 17:02
Alternative autonomous modes Jon Reese Programming 1 14-01-2004 13:17
