Go to Post What is the coefficient of friction between butt and carpet? - JVN [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
  #76   Spotlight this post!
Unread 12-04-2006, 21:20
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
Re: Online Aim High Game
just a thought but there is no item to change the speeds of the bots. like if the blue lowbot is pushing and the red highbot pushes then other way the blue bot should slow.
nice updates
  #77   Spotlight this post!
Unread 12-04-2006, 21:28
Billfred's Avatar
Billfred Billfred is offline
I've noticed with the recent update that I can't control the robots anymore. Neither side's controls work coming out of autonomous (or even without autonomous).
  #78   Spotlight this post!
Unread 12-04-2006, 21:44
Back after 4 years off
FRC #5279
Did you have caps lock on? I did and when I turned it off it fixed the problem.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
  #79   Spotlight this post!
Unread 12-04-2006, 23:03
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
i cant get shoot to work =( i have the perfect drive out + turn... but it never shoots =( it sadens me...
"f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f ,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f ,f,f,f,f,
f,f,f,f,f,r,r,r,r,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s, s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s"
yes i take out the return in it...
and the low bot is WAY to slow now =( *got slow bot auto to run yay but still no shoot on high bot...
and you dont have the winner of auto starting on defense =X
*getting it to shoot now... but Auto seems to end at 123!!!! not 120 =( and i only get into position for low goal by 125 and only get 5/10 balls out on the low bot =/
BUG - blue midbot can not shoot out balls from bottom... *EDIT* mid can only shoot out what it picks up not in auto =( thats sad =(
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
  #80   Spotlight this post!
Unread 12-04-2006, 23:26
New post for BIG PROBLEM
ok so its wierd and spotty from bot to bot but sometimes you cant use balls from your robot after auto... =(
also when you do win auto you dont go on defense it seems to still be random...
MID BOT - red dumps in auto (all 10)... Blue cant... using this
"f,f,f,f,f,r,r,r,r,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f ,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f ,f,f,f,f,
f,f,f,f,f,f,f,f,d"
high bot - both bots shoot + score but ONLY 5 of them!!!!
blue went on offense... red could shoot balls blue couldnt...
"f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f ,f,f,r,r,r,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f ,f,f,f,f,f,f,f,f,f,f,f,s,s,s,s,s,s,s,s,s,s,s,s,s,s ,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s ,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s ,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s
*ok you can use balls
  #81   Spotlight this post!
Unread 12-04-2006, 23:33
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
oh yeah winner goes on DEFENSE! hah. i had it set on offense. i can look into that bug about not using balls collected in auto, theres a good chance i know what i did wrong with that one...
and also if red is unloading on bottom blue cant unload till reds done I HAVE NO IDEA WHY
i dont know whats goin on with the ending at 123 thing sorry, i have gotten all my balls in with the high bot when i use the code above. dunno what to say, sorry :-(
ummm ya, im working on a downloadable version right now. should be fun.
i started making one for the triple play game, and gave up 6 minutes later
so ill see what i can do about those bugs. i knew the autonomous would have a plethora of bugs, so ya, ill see what i can do. check back tomorrow, should be fun.
***ya ok, so where i thought i might find the problem, there was none. i cannot explain whats going on, so ure gonna hafta deal with it. there is a no autonomous option if you ignore the code input area and just press start, it will start at 120 like it used to. sorry i couldnt get it to work better
and by the way, theres always been stupid stuff wrong, for the first few version, there was no ball#1. there were only 39. i couldnt get ball1 to exist, then in later versions it started showing up! who know when autonomous will just start working (sounds like the real competition ;-)
******im trying not to post too many times, so im just editing. i made an update. in autonomous you automatically go your max speed. this means everyone needs to rewrite their codes (sorry)
but what i can tell you it, you dont need to change your lowbot code, for your midbot code you need to take out half of your f, and b, because its moving twice as fast, and for your highbot code, take out 2/3 of your f, and b, because its moving thrice as fast. sorry for the incomveniance, but it had to be done.
-turkey
  #82   Spotlight this post!
Unread 13-04-2006, 09:04
AKA: Andrew
new subject, new post
i have compiled 3 seperate presents or everyone.
first, is the shareware version of the online game. its a zip file with instructions and an an html and a folder of suporting files. you can distribute it and upload it as much as you want, as long as credit is given where credit is due, and you do not alter the files.
second is a windows exe of the game. everyone loves free, fun downloadable games, so here it is. same rules aply to this, you can distribute it to anyone you want as long as its for free and props are given whree props is due
third is a mac version (yes a mac version, you heard me correctly) of the game. same rules apply as above.
i will atach the version 12 of these to this post, but these and all updated verson will be available off of the mechtechs website, which hopefully you know the URL of by now. but just in case...
www.team422.com/aimhighonlinegame.html
enjoy yourgoodies,
-turkey
  #83   Spotlight this post!
Unread 13-04-2006, 12:06
tfisher04 tfisher04 is offline
AKA: Tom Fisher
FRC #0422 (Mech Techs)
tfisher04 has a spectacular aura abouttfisher04 has a spectacular aura about
All of the Shareware versions and the latest version of the game itself is available via the above link to the team422.com website. Good luck when playing!
  #84   Spotlight this post!
Unread 13-04-2006, 12:27
Hiteak's Avatar
Hiteak Hiteak is offline
Improving the Technology World
AKA: Dan Schneiderman
FRC #3157
Hiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond repute
Send a message via AIM to Hiteak
f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,f,l,l,l, l,f,f,f,f,f,f,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s, s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s, s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s, s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s, s,s,s,s
Blue high bot^
It should get allif not most balls in
RIT '13
Computer Science House Member
Working towards improving technology policy
Student: Team 1930, 2005-2008
Mentor: Team 2999, 2009
Ruckus: 2006 -2010
Volunteer:
NJR: 2008
FLR: 2009, 2010
  #85   Spotlight this post!
Unread 13-04-2006, 12:32
AKA: Andrew
MAJOR MAJOR UPDATE
first off, the lowbots speed has been increased to that of the midbot. i thought it was necesary
secondly, due so some complaints, i have simplified autonomous coding by alot. now, you type the function you want performed (f,b,r,l,d,s,p) follwed by the number of frames to perform it. MAX OF 9 if it is a two digits number, then it will screw everything up. so the old versoin of f,f,f,f,f,f,f,f,f is replaced with f9.
if you shoot or dump, just use 1 so you dont do weird things.
for shooting on the midbot, because he can only shoot once per second, use the pause, so his command becomes s1p9p2 for a shoot, and copy/paste 10 times and he will try and shoot all 10.
for shooting on the highbot, he can do it thrice a second so use s1p3 copy/pasted a bunch
raming in autonomous is cool, and the low/midbots can get to and ram the highbot before he is done shooting, so thats good.
hopefully it will be available on the team422 site soon, but until then it can be found on
http://www.geocities.com/gogogadgetmiester/
good luck, and share your now simplified autonomouses!
-turkey
  #86   Spotlight this post!
Unread 13-04-2006, 13:37
Billfred's Avatar
I love the new scripting language for autonomous. Simple, easy to understand, easy to execute. (f9f9l4s. That's all I'm saying.)
My current high score is 224, and that's including a 40-point play (and the blue robot remaining a paperweight).
Keep up the good work!
  #87   Spotlight this post!
Unread 13-04-2006, 13:52
AKA: Andrew
ok, it isnt on the team422 yet, but its on the www.geocities.com/gogogadgetmiester/
i finally fixed a bug thats been bugging me since the start. if you go to dump at the same time, it wont let you. turns out a break statement was owning us all. i fixed it, and in the process found that there was a bug inthe auronomous shooting (they both took balls out of the blue hopper, but recorded that they didnt)
so thats all fixed and on the geocities, hopefully it will be on team422.com soon. remeber, you can download the shareware version, give it to your team website guy and he can host it on your website if you want. there is also the exe and mac version available for download and offline play. they arent the most updated version though. they will be soon though i assure you
till then enjoy the less buggy program
and billfred, all i have to say is f with a lowbot
PWNAGE
which is why i prefer:
f2l4f9f9f6r3s
cheap and unramable. with autonomous isnt the highbot too much of an advantage? 40 points guaranteed, the lowbot can get 10, midbot possibly like 15-20. but with 40 in auto, even if it is taken out of the game by a pusher for the rest of the game it wins. hmmm, sounds familiar....
-turkey
  #88   Spotlight this post!
Unread 13-04-2006, 15:33
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
The red goal doesn't seem to be activated during autonomous.
I may be wrong.
  #89   Spotlight this post!
Unread 13-04-2006, 15:37
AKA: Tom Fisher
Now the newest version is on Team422.com. Here's the address. The updated shareware and stuff is at the bottom of the page.
http://www.team422.com/aimhighonlinegame.htm
  #90   Spotlight this post!
Unread 13-04-2006, 16:58
AKA: Andrew
ive pretty much run out of things to improove, so im starting a list of good autonomouses, heres what ive got so far:
highbot:
-f9l3f9s - real simple, easy to remember
-f2l4f9f9f6r3s - awesome. you get them all in, and you shoot from behind the platform so you CANNOT get rammed
lowbot:
-f3l4f9f9f9d1p9p9p5b9d1b9b9r4f9f9 - if you have a copy/paste available this is where its at. you dump, come back, and position yourself for the start of the match. if you ad a final f to the end you will continue down and ram someone at the last second, after theyve gotten their balls off
-f9f9f9f9f9f9f2r4f - will let you run around behind the corner the highbot is hiding behind. you wont get there in time, but hey, yull be there
midbot:
-same as above for raming
-keep in mind typing f will be the simplest ramming
-f9f9f9f9f6b9l4f2s - a nice midbot one, will take out a simple highbo autonomous, then go back and put in like 5 or 6
2006 AIM HIGH strategy board now available! Dillon Compton Rules/Strategy 4 27-03-2006 15:42
FIRST is all mixed up.... Swan217 General Forum 11 23-03-2006 18:28
Aim High Dodgeball! Cyberguy34000 General Forum 26 18-01-2006 22:26
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
