Go to Post FIRST is a pretty decent microcosm of real life, those who work hard, accomplish more decent lesson to learn, and FIRST is allowing us to learn it. - Aren_Hill [more]
Unread 13-04-2006, 00:10
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Re: Potentiometer 5 or 6 detents
Here is a photo of our switch from last year, which was connected to the RC. It’s a six position switch with five 22k resistors (100k / (# positions - 1) = 20k, 22k was the closest we could find at Radio Shack). The switch positions were then 0k, 22k, 44k, 66k, 88k, & 110k. This would give analog values of about 0, 205, 410, 615, 820, and 1024. In the autonomous code, we looked for a range of 205, centered on each of those values.
void User_Autonomous_Code(void)
	switch (((Get_Analog_Value( rc_ana_in01 )+100)/205)+1)	//read autonomous switch
		case 1:	//switch position 1
			while (autonomous_mode)   /* DO NOT CHANGE! */
				if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
					Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
					/* Add your own autonomous code here. */
					Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
			break; //end of case 1
		case 2:	//switch position 2
		default:
			// something's wrong - do nothing
	}  //switch
}  //User_Autonomous_Code
Best source for a potentiometer? railerobotics Electrical 20 28-11-2007 22:24
Confused about potentiometer values Kirk Technical Discussion 4 11-03-2006 16:29
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
