Go to Post You will forever be confronted with choosing between right and wrong, or choosing what you think you can get away with. Which way you go defines what kind of person you are. Choose wisely. - Gary Dillard [more]
Unread 12-04-2006, 02:27
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Combining camera + encoder code
Hey all!
I took the camera.c, camera.h, tracking.h, etc.. and put it right into the encoder code that kevin watson designed earlier in the year. I did some slight modification to the code so that the camera doesn't use the servos to move, it uses the drive train to move around. I tested all the code in the normal camera version of the code, and it works flawlessly.
Now when I took the encoder version of the code and combined it with all the files that Kevin Watson specified to include in the code written in camera_readme.txt, serial_ports_readme.txt, and tracking_readme.txt. I have everything the readme ask for. The code builds, the encoders work, but the camera says that there is No Camera Found!!!!!!!
Any ideas!??!?!
Thanks!
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 12-04-2006, 05:41
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Combining camera + encoder code
are you handling the camera interrupts in user_routines_fast.c?
Robot Inspector
Unread 12-04-2006, 18:48
kiettyyyy's Avatar
Yes I am .. Could it be that I called the get or put data after the startup of the serial ports? Who knows.. Ill try some other stuff at the practice field today.. talk to yall soon
-Kiet Chau
www.team1538.com
Unread 12-04-2006, 20:33
The encoder version of serial_ports.c sets serial port 2 (the TTL serial port) to 9600 bps while the camera version sets it to 115200.
Which one are you using? It should be the one from the camera.
Unread 13-04-2006, 00:53
kiettyyyy's Avatar
Oh! Yeah i just found SPBRG2 = BAUD_9600; // baud rate generator register [251]
Was that what you meant?
[edit]
Yep i found it inside the code now.. Ill replace it and test all of it tomorrow
Thanks everyone!
[/edit]
-Kiet Chau
www.team1538.com
Unread 13-04-2006, 09:39
[edit]
Thanks everyone!
[/edit]
Make sure you change the line after it also to TXSTA1bits.BRGH = 1;
Or just copy the entire file from the camera project.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Combining ADC, Serial, and Camera_s codes kaszeta Programming 6 22-01-2006 20:23
Camera Code Fishdude404 Programming 1 25-01-2005 18:59
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
