Go to Post Hey... wait... that looks like a LEGAL bumper configuration! You can't post a photo with a legal configuration... we'd have nothing to talk about! - dtengineering [more]
Unread 14-04-2006, 14:17
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Exclamation VEX controller not recieving wireless commands
I searched for solutions to this to no avail on the forums, so if I missed something, please point me in the right direction.
I turn on my vex bot and controller and there is no signal between them on channel one. Everything is hooked up correctly, ports and channels match, have tried reloading the default code, and recharging the batteries, no good. The tether does work however, it just seems to be the wireless that is having a problem.
So, what solutions have there been to fixing this problem and various problems like it, not in the FVC but just typical home use? Thanks.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 14-04-2006, 14:41
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Re: VEX controller not recieving wireless commands
Well first of all, in your programming did you have a while loop? I made the mistake of not including while 1 == 1 in my code so it didn't work.
2) All the motors correspond and are plugged into the right ports?
3) Battery and RC are all plugged in?
4) You have the correct crystal for the controller?
5) Nothing happened to it?
6) The rx ports are correct?
Can you post a pic of your bot so I can see it? Just how the motors are setup, etc. Make sure the battery and all that fun stuff is plugged in right. How long have you had the kit? Try switching it to a different channel (5 or 6) because I know my controller joysticks wasn't giving full power to the motors, but the buttons were.
VEX Robotics Blog
Unread 14-04-2006, 15:02
AKA: Joeseph Smith
FRC #0066
1. I'm running off of the default code for now. No programming.
2. For single joystick control, I do have both motors in ports 1 and 2. As I said, it did work with the tether, its just the wireless communication that's going haywire.
3. Yup
4. Both original crystals are in their respective locations
5. It was working just fine yesterday until this problem occured. Nothing happened to it for this to be a consequence. In short, it did it to itself.
6. Rx ports are correct indeed.
Did try changing channels, nothing happened.
pic attached is of the controlloer. You may not see the antenna module because I placed it under the robot. Remember, it did work with the tether, its just the radio control that's becoming problematic. Thanks
Joeseph P. Smith
jpthesmithe.com
Unread 14-04-2006, 15:31
UnderDark's Avatar
UnderDark UnderDark is offline
Alumni
AKA: Matthew Korzeniowski
UnderDark will become famous soon enough
Is it possible you damaged the RC itself?
Try asking for help on http://www.vexlabs.com too. They make this after all.
"My gaming is FIRST!"
-Joe Jagadics
"I am like an all powerful warloard"
-Brian Graham
Unread 14-04-2006, 15:36
AKA: Joeseph Smith
FRC #0066
I doubt that very much.
You think I should try to replace the crystal???
[Edit] OK... the wireless starts to work again, and I did nothing to it....
*SIGH*
Perhaps I should ask this: is it normal for VEX bots to have occasional radio transmission problems??? What is the fix to make sure it doesn't happen again???
Joeseph P. Smith
jpthesmithe.com
Unread 14-04-2006, 15:51
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Try taking your crystals out and putting them back in perhaps they are loose.
Maybe your next door neighbors or something in your house is causing radio interference, try moving your robot to a different location.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 14-04-2006, 16:59
irishninja's Avatar
AKA: Nathan Bixler
This probably sounds super condescending but it isn't, are you extending the antenna on the controller all the way? I've had my vex kit for three weeks, and I still sometimes forget to extend it.
VEX Robotics Blog
Unread 14-04-2006, 17:06
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
it may be a wireless thermostat, in our team room we have very hit and miss reception because of that
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 14-04-2006, 20:19
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Make sure to extend the radio antenna when using the Vex robot, and also make sure that the antenna from your controller is PARALLEL to the antenna on the RC. If you point the antenna directly at the RC, or perpendicular to the antenna, the RC antenna will not receive the transmission (yes, this is a problem that occurs, we've had it happen during testing).
Antenna placement can also affect it. I did notice that when we had our robot with the back facing away from us, we did not transmit as well (the antenna was on the back behind a metal plate, conveyor belt, and a few motors).
Unread 14-04-2006, 20:36
irishninja's Avatar
AKA: Nathan Bixler
Also, did you check the batteries? Is it just weight of robot? Lift up the robot and try to move around. I've built a couple robots where when they were on the ground they just didn't move because there was too much stress, but after lifting it up it moved.
It looks like you cut the RC to make room for the motor in the picture. Can you explain that?
VEX Robotics Blog
Unread 14-04-2006, 23:06
AKA: Joeseph Smith
FRC #0066
Update, I did buy up some new crystals, and now its working fine. I probably got a bad one in the starter kit. Either that or it went bad after a few days.
As far as the motor is concerned, have a look at the attached photo (close up) and you will see I came within < 1mm of the top of the RC. How that worked out, beats me, but that's why I tinker more than plan most of the time.
Joeseph P. Smith
jpthesmithe.com
Unread 15-04-2006, 17:03
jeffmorris jeffmorris is offline
jeffmorris is on a distinguished road
Try resetting the RC transmitter by by clearing the configuration data following the instructions on page 6-16 of the "Inventor's Guide".
Making the VEX OI (controller) beep? ForgottenSalad FIRST Tech Challenge 2 27-03-2006 08:50
Programming VEX Controller HRobotics Programming 4 21-03-2006 23:25
Vex controller - outputs not working jrecht FIRST Tech Challenge 2 06-02-2006 23:26
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
