Go to Post A thread already exists (and boy, does it exist!) on the topic: - Billfred [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 14-04-2006, 14:25
FRC #0701 (RoboVikes)
Rube goldberg project...
okay so for our physics class we have to make a project which completes a simple task (this year its to cut paper) in a complex way (ever heard of rube goldberg....? google him!)
we get extrapoints for different energy transformations (i.e heat-->mechanical, chemical--->light electrical--->light) and we get extra points if the machine is resettable within 15 seconds.
we've figured out how to do everything except heat, and still make it resettable. we drop a coin which connects a light bulb, then
Basically we wired a photosensor--->transistor --->vinegar battery---> another transistor---> another lightbulb
the vinegar battery counts as chemical, the light triggers the photo sensor (light---> electrical) which allows current to flow through the vinegar battery through the transistor which relays power to the next light, this step is repeated 6 times (one lightbulb turns on the next photoresistor which turns on the next bulb which turns on the next photo resisotr etc. etc..) , the maximum number of each energy transformation is 6 so... of course to maximmize bonus points we do it 6 times.
mechanical is very easy (use motors or something) but we are boggled about how to make use heat to triggers something and still have it resettable so everything works the next time through.
any ideas?
Team 701
Unread 14-04-2006, 14:27
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: Rube goldberg project...
This may not be resettable in 15 seconds, but ..
http://www.chiefdelphi.com/forums/sh...ad.php?t=46503
Brandon Martus
e-mail
Unread 14-04-2006, 14:35
anyone have experience with circuitry and stuff
i don't know if this would work but i was thinking of wiring an NPC Thermoresistor into a NOT logic gate, then wrapping the resistor in a heating element, so when there is heat the resistor will increase its resistance and not allow current through.
my question is will these types of resistors lower the current enough to trip a logic gate?\
OR does anyone know where to buy Bi-metal strips?
Team 701
Unread 14-04-2006, 15:02
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
I did one last year to change the batteries of a flashlight and have it turn on. I still have pictures of it actually (i think...).
As far as using heat, do you have a time limit for all of this to happen? If not, you could try melting ice to do something... ice is easily replaceable.
So if you have a net of some type with ice in it, and you melt the ice, the water can go through and add weight to a certain bucket that can then trigger another step. You can melt the ice by turning on a blow dryer or whatever else you might want to do.
hope it at least switches on a light bulb for you...
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 14-04-2006, 15:31
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Get an old toaster, and grab the bi-metal strip out of that. Of course, that might be asking you to heat up your device too much - not sure if you are allowed to use that much electrical power. Set it up at the beginning, and have it auto shut off after it trips. That should let it cool off enough for the next round.
Heck... can you just USE a toaster?
Brian Graham
Unread 14-04-2006, 19:03
well we don't have enough time to melt ice, and the thing is we are running 6 volt lantern batteries so it's not exactly enough to cause a lot of heat...
Team 701
Unread 14-04-2006, 19:39
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I'm partners with Salik on the same project.
Just had an out-of-the-box thought. If instead we cooled something down to activate a trigger, it would still be considered a heat transformation right? However, i'm having trouble going anywhere with this idea. So i'm handing off the torch (no pun intended) to anyone with some ideas.
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Ideas for my Gold Award Project Sarah Bowes General Forum 4 24-06-2005 18:25
Project Helping Hands: A F.I.R.S.T. Charity Petey General Forum 6 30-03-2005 23:20
openFIRST Project Status Immediately after Kickoff Timothy D. Ginn FIRST-related Organizations 0 05-01-2005 14:53
Preseason project AdamT General Forum 4 09-09-2002 00:52
