Re: 6WD?
if you can find a radio shack that still has one, you can probably pick up a programming kit for $50. failing that how about making up a pwm y cable to feed the signal from a single port to two motors.
Re: 6WD?
Be careful using pwm wye cables to drive two motors. The vex motor ports are only rated for one amp. The programming kits are on sale again, through June 3, for $49.99 many stores still have them in stock.
Re: 6WD?
Re: 6WD?
Re: 6WD?
| Collaborations | hayakuneko | General Forum | 46 | 29-03-2006 11:37 |
| Questions about first time trying 6WD. | Darkswordsmith | Technical Discussion | 15 | 18-02-2006 21:21 |
| 4wd vs 6wd? | Yov | Technical Discussion | 22 | 06-01-2005 00:09 |
| confirmed... 6WD recommendation of Joe J.. | archiver | 2001 | 0 | 23-06-2002 23:20 |
| tank or go-cart style steering? | archiver | 2001 | 17 | 23-06-2002 22:42 |
