Go to Post Is FIRST making it too easy?... yes they are making it easier than years past. But I would also say that does that matter? If students are still inspired to pursue more advanced designs and eventually a career in the technology sector we still have met our ultimate goal. - MikeDubreuil [more]
Unread 14-04-2006, 11:50
Billfred's Avatar
Billfred Billfred is online now
A self-returning linear pot?
I've been tinkering with some projects in my head, and while running the board at WUSC I figured out how to control one of them: a linear pot. But to make it better for the situation, it'd be awesome to have it return to the center automagically (or at least have a detent in the middle to let the operator know it's centered).
Does any such a device exist (cheaply)?
Unread 14-04-2006, 12:02
Re: A self-returning linear pot?
I Googled on "potentiometer sliding" and found a bazillion hits. Here's a link to a manufacturer: http://www.ctscorp.com/components/Datasheets/442.pdf.
Have fun.
Edited to add: I found a number with center detents, but not self-returning. Have you considered a string pot with some sort of custom-made mechanical doohickey as the controller?
Unread 14-04-2006, 12:14
Would a joystick work? They tend to have a somewhat linear motion and return to center automagically.
Here are two more pots with center detents: http://bourns.com/pdfs/PTA.pdf and http://bourns.com/pdfs/PTA.pdf
Unread 14-04-2006, 13:03
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Have fun.
No doohickey needed. Just attach a spring to it. Have the shaft of the potentiometer go through the windings of the spring. As you turn it, the spring will unwind and once you stop putting force on it it will snap back to place.
http://www.mikesorrenti.com/
Unread 14-04-2006, 13:51
Bill,
What console are you working on? Lot's of companies make detented pots. Many people don't use them because it requires another pot in series that can calibrate the detent.
Modern digital consoles can have a programmed stop stored in memory that fixes all the problems with much less expense.
Unread 14-04-2006, 14:06
Billfred's Avatar
Originally Posted by Al Skierkiewicz
Bill,
The IFI OI--the idea just happened to come to me while doing my show.
Unread 14-04-2006, 14:42
No, what audio console do you do your show on?
Unread 14-04-2006, 16:35
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I think I follow what your trying to do. Make a control for some function that can attach to the OI by using a "self centering slider pot". Correct?
If so, a very cheap solution is to attach two springs of equal length, diameter, and wire size to the slider pulling in opposite directions. Make sure you stretch them equally and have enough travel on both to have the more relaxed spring still is in tension when the slider is at full travel. Now when you move the slider off center, the spring forces will pull the slider back to center when released.
Look inside a joystick, you will see a similar setup pulling the stick back to center.
Unread 14-04-2006, 16:53
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
you may want to try an airpot i found an ad in design news it looks real cool
www.airpot.com
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 14-04-2006, 22:06
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
Some sound and lighting boards have computer controlled presets where the board can return the pots (sliders) to any preset position. Is that the kind of board you are talking about?
I would guess that the pots have either a servo or stepper motor to return them to position. I don't know if the feedback mechanism is the pot itself (most likely, since the OI processing part of the boards are pretty much purely digital anyway), or yet another position sensor. It's also possible that the sliders are not pots at all in some of these boards, and are actually optical position sensors.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
pot sensor selection wkethman Electrical 5 24-02-2006 11:28
Lead Screw or Linear Motion Source evolution Kit & Additional Hardware 10 13-02-2006 13:49
Flywheels achieving linear motion mechanicalbrain Math and Science 22 31-01-2006 20:27
Pwm and pot Zoom Programming 6 29-01-2006 18:47
Shallow Pot Magnets on Tetra Coachmac Rules/Strategy 4 18-01-2005 12:15
