Re: Victor-PWM Cable connections
An old fix that i can remember using on the old victor with the old style of PWM connector was to put a small dab of hot glue on the connector, this can also be done on the other end where they all connect to the RC. Using hot glue makes them stay in place but you can peel it off if you need to remove the connections.
| Ribbon Cable | emusteve | Electrical | 6 | 13-01-2006 16:33 |
| 2 questions about LAN (10/100) cable. | Elgin Clock | IT / Communications | 19 | 16-11-2004 12:04 |
| Breaking Cable | WebWader125 | Technical Discussion | 13 | 28-05-2004 16:44 |
| Fun Times at the Hardware Store | sanddrag | General Forum | 10 | 19-03-2004 23:55 |
| LEGO IR tower cable | Jeff Rodriguez | Chit-Chat | 1 | 31-10-2003 16:23 |
