Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
Unread 15-04-2006, 04:40
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Victor-PWM Cable connections
Hello all,
I am wondering what fixes teams have come up with to ensure a good connection between the Victor Speed Controllers and its PWM Cable.
What happened: During the final rounds at Davis, one of our drive motor Victors started continually blinking orange (no signal). We traced the problem to a bad PWM cable connection. We did replace a fried Victor right before this problem occurred, so I would assume that our cables were just unseated during this process. We did, after this, make sure the PWM cables were plugged all the way in, which they were. I am wondering how the PWM cable does not make contact if it is all the way down (vertically).
Also, our victors are mounted on the bottom of our robot, so it would be rather unlikely for the cable to just "pop out" of the Victor seating, plus they are electrical taped in to avoid this very problem.
If the connections are so precarious to unseat and lose the connection that easily, how and why do they withstand competitive matches? Or don't they?
What have you come up with to solve this problem?
Thanks a bunch in advance,
~Stephanie
PS--Searched, these threads may be useful too:
http://www.chiefdelphi.com/forums/sh...m+connec tion
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 15-04-2006, 07:00
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Victor-PWM Cable connections
I don't know how much help this may be but here it goes, This problem has been around for the past few years and well there's really not a whole lot you can do about it, when I first joined in 2002 the Speed Controllers had a slight design change then what they are now which was the cable would just sit in the speed controller which was a major headache because then the cable could wiggle freely about. After I think '02 or '03 IFI revised the speed controllers so that they would have a small rectangular piece around the area the cable goes in. While this solved the problem of the cable moving freely about, a new problem came up and that was you could never tell if the plug was all the way in or lined up with the holes.
Now as for a solution maybe there will be another revision to the speed controller for '07 depending on how many teams let IFI know of the problem of the PWM Cable being plugged into the speed controller.If teams don't let IFI know of this problem at the competitions or if they don't email or call IFI then nothing will get resolved.
The only solution(s) that I can think of right now:
1) Leave the robot powered on and communicating and reseat the cable till the speed controller has a solid amber light that way you won't have to guess if the wire is in all the way or if all the pins are in the holes and you can see the status of the speed controller as your doing it, after that find away to hold the cable in place so that it doesn't pop out.
2) Is if IFI makes the speed controller in a way that when you plug the cable in it snaps into place ensuring that the cable is secured correctly and is lined up with the holes.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 15-04-2006, 08:38
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
There is a device that is sold at one of the Robot parts sites like
"Robot Marketplace"
http://www.robotcombat.com/marketplace
that is a PWM clip. They keep down pressure on the wire. This clip takes space and will require access to the speed controller.
I am not seeing the part but am sure this was the site.
Mike Martus
Unread 15-04-2006, 10:03
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Correct link.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 15-04-2006, 10:15
DonRotolo's Avatar
Back to humble
FRC #0832
How about the other end: We had some issues with the PWM cables popping out of the RC. The way we mounted the RC it was difficult to see, leading to some puzzling moments...
Does anyone have a good way of keeing the cables on to the RC, aside from hot melt glue (which, in my experience, eventually comes loose)?
Don
Unread 15-04-2006, 10:28
Billfred's Avatar
Billfred Billfred is offline
I haven't tested this, and as such I'm not making any warranties, but what about a thin bar that goes through all of the PWM cables just above the connector and keeps the RC connection from being pulled up accidentally? (I'm imagining something like the gates to the FRC field, except the other end would unlatch as well.)
Unread 15-04-2006, 11:15
in between teams
AKA: Luke Van Oort
I never had this problem this year, although I was told by the guy who wired last year's 'bot that he had this problem and I should be careful. So, I looked at the board differences, and the only major difference I can see is this year's has less distance to the controllers from the RC and there is zero stress. The whole setup is also mounted at a 90 degree angle to the floor as opposed to flat as in last year's I don't know if that helped it or not...
Team 1219: 2009 - Mentor
Unread 15-04-2006, 13:20
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
An old fix that i can remember using on the old victor with the old style of PWM connector was to put a small dab of hot glue on the connector, this can also be done on the other end where they all connect to the RC. Using hot glue makes them stay in place but you can peel it off if you need to remove the connections.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 15-04-2006, 17:11
RbtGal1351's Avatar
AKA: Stephanie
FRC #1351 (TKO)
We electrical taped our PWMs to the RC, and our RC was at a 45 degree angle facing down, and had no problems.
(But I can't guarantee that this will work, seeing as our Victor PWMs were electrical taped and they were mounted right side up... )
Originally Posted by KTorak
Correct link
How does this help?
Thanks
~Stephanie
SVR 07: 36th seed
Unread 15-04-2006, 22:39
in between teams
AKA: Luke Van Oort
How does this help?
I think he means this. About 2/3s of the way down, they clip on and hold the PWM.
Unread 15-04-2006, 23:18
KTorak's Avatar
Fire Rescue 47
AKA: Kyle Dersch
Team Role: Driver
Sorry about that. I know I navigated to the right page with the item...but it must not have copied it.
Unread 15-04-2006, 23:56
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
We had some cables/Victors that would not consistently make contact even though the cables were seated all the way down. We very slightly bent the middle pin so that the three pins were not exactly in a straight line. This seemed to take care of the problem.
Unread 16-04-2006, 18:10
AKA: Dr. Brooks
no team (WRRF)
Hello all,
The wadded up extra length of the pwm cable can present an extra
bit of mass that wiggles the cable when the robot moves. We cut
our PWM cables to the required length, replacing the female end with
a Molex C-grid connector, using the "high force" sockets. We don't
use the C-grid connector on the male end, the pins seem to be too
short to make a good connection to the victor/spike.
The cable itself is zip tied to the electronics board right next to the
controller, or the victor, so that the cable comes up and over with a
inverted U shape, providing for stress relieve in the event of impact.
Attaching the electronics so that the force of typical impacts is
perpendicular to the connector, removing the tendency of the impact
to pop it out, is a good idea.
We check all of these connectors between every match to make sure
that none are walking off, and we keep track of any that might be
moving. If it moves a half millimeter when you push a little with your
fingernail, it is walking off and you need to do something about it.
There is no substitute for checking the connectors between every match,
and laying out the electronics to make it easy to do this without bumping
wires, but you can take measures to improve things:
* You can make a bracket that pins the connectors down when
it is screwed to the electronics board. With due attention to the
possibility of a short, the 3 dollar clip available at robot marketplace
would seem to work for a victor, but you need a single bracket to
hold a large number of connectors on the RC. I would want these
brackets to be made of plastic to reduce the chance of a short,
but the aluminum ones on our robot this year were insulated
with electrical tape. If you have th luxury of using every other
PWM output on the controller, you can make a "comb" style of
bracket that will hold the connectors better.
* Another strategy is to glue the female connectors to each other
as you install them on the RC, producing a single connector with
a large pin count. The resulting high pin count connector is almost
impossible to walk off, although you can get if off if you need to.
The drawback here is that if you need to replace one cable for some
reason you get to do some cutting, but it produces a connector that
does not walk off without using a bracket. We use this strategy for
the array of switches used to provide autonomous modes, or inhibit
motors for safety in the pits, that are connected with a single multi-
conductor cable.
Unread 16-04-2006, 20:07
Umm Errr...
Overall, PWM cables seem to be the #1 source of electrical system problems. .1" headers are NOT designed for this type of application. They are however the standard for RC control. I prey that they will change during the next IFI design cycle.
As far as fixes, our team hot glues all of our pwm cables in place. Hot glue holds well enough to keep them where they belong, but also breaks away cleanly if you ever need to change something. We also use electrical tape to make a single connector our of the RC side connections.
1139 Alumni
Unread 17-04-2006, 21:54
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
Those look like a good idea, unless the metal cuts into the cable, or shorts out something else, but you should be able to avoid those problems.
One thing we did on the RC side, at least for our sensor connectors, was use one large connector block to hold all the wires, so it's easier to hold in place.
BTW: Here is the image from the robotcombat web site of the Victor PWM Clips:
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Ribbon Cable emusteve Electrical 6 13-01-2006 16:33
2 questions about LAN (10/100) cable. Elgin Clock IT / Communications 19 16-11-2004 12:04
Breaking Cable WebWader125 Technical Discussion 13 28-05-2004 16:44
Fun Times at the Hardware Store sanddrag General Forum 10 19-03-2004 23:55
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
