Make our own VEX programming cable?
Has anyone just tried to make your own VEX programming cable? We would like to have an additional one around. Does anyone know any information like a pin out?
Re: Make our own VEX programming cable?
Why? You can buy them from Radioshack for $50.00 now. You could also check
aat vexlabs. I think they have them for less. |
No programming kits within MILES of our location or online. I snagged one on eBay however. I'll just have the kids ohm this cable out and we can make another for a spare.
It's not simple to duplicate the programming modual. It's a usb to serial cable and that little orange box. In that box is a microcontroller that handles the programming. Not an easy thing to clone.
It's doesn't HAVE TO BE a USB to Serial cable does it? Our Dell D810 has a real serial port on it.
I know all about USB to Serial converters. I have my own design. I use a FTDI USB serial chip to handle the RS-232. Other cables for reference... http://www.plccables.com bottom line, no problems. I am using the FTD FT232BM chips. http://www.ftdichip.com/Products/FT232BM.htm - Last edited by Chris_Elston : 17-04-2006 at 23:25. |
You can use another usb cable as long as you use the right driver. I believe others have used a serial cable. That's not the problem. It's the code on the pic inside the little orange box.
| Programming Vex w/ MPLab | dababyjebus | FIRST Tech Challenge | 27 | 25-04-2008 09:11 |
| vex programming arcade drive setting | Michael Leicht | FIRST Tech Challenge | 3 | 17-10-2005 21:26 |
| White Paper Discuss: VEX / intelitek easyC programming document | dez250 | Extra Discussion | 3 | 15-09-2005 15:20 |
| Vex Programming | foobert | FIRST Tech Challenge | 3 | 24-06-2005 01:09 |
