Go to Post Tragedies happened. We've learned from them, as individuals, as teams, as a community. - Taylor [more]
Unread 15-04-2006, 18:49
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Make our own VEX programming cable?
Has anyone just tried to make your own VEX programming cable? We would like to have an additional one around. Does anyone know any information like a pin out?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 17-04-2006, 21:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Make our own VEX programming cable?
Why? You can buy them from Radioshack for $50.00 now. You could also check
aat vexlabs. I think they have them for less.
Unread 17-04-2006, 21:23
Controls Engineer
AKA: chakorules
No programming kits within MILES of our location or online. I snagged one on eBay however. I'll just have the kids ohm this cable out and we can make another for a spare.
Favorite CD quote:
Unread 17-04-2006, 22:38
Gdeaver Gdeaver is offline
FRC #1640
It's not simple to duplicate the programming modual. It's a usb to serial cable and that little orange box. In that box is a microcontroller that handles the programming. Not an easy thing to clone.
Unread 17-04-2006, 23:19
Controls Engineer
AKA: chakorules
It's doesn't HAVE TO BE a USB to Serial cable does it? Our Dell D810 has a real serial port on it.
I know all about USB to Serial converters. I have my own design. I use a FTDI USB serial chip to handle the RS-232.
Other cables for reference...
http://www.plccables.com
bottom line, no problems.
I am using the FTD FT232BM chips.
http://www.ftdichip.com/Products/FT232BM.htm
Favorite CD quote:
Unread 18-04-2006, 00:02
FRC #1640
You can use another usb cable as long as you use the right driver. I believe others have used a serial cable. That's not the problem. It's the code on the pic inside the little orange box.
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 17-10-2005 21:26
White Paper Discuss: VEX / intelitek easyC programming document dez250 Extra Discussion 3 15-09-2005 15:20
Vex Programming foobert FIRST Tech Challenge 3 24-06-2005 01:09
