Go to Post I would be thankful to just participate in champs, I would be happy with just that. - Brandon_L [more]
Unread 16-04-2006, 10:54
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Finding zeros (math homework)
I missed some school and therefore some school material. So my question is, how do you find the zeros of a quadratic relation without using a graphing calculator?
Thanks
Unread 16-04-2006, 11:06
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Finding zeros (math homework)
You use the quadratic formula:
x = (-b +- sqrt(b^2 - 4ac))/(2a)
(where a, b, and c refer to the coefficients of the equation in the form y = ax^2 + bx + c)
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 16-04-2006, 11:13
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
So say my relation is A = w(20-w), I'd solve that by making w=0 and 20-w = 0? So all this is, is substitution? Guess and check?
Unread 16-04-2006, 11:18
in between teams
AKA: Luke Van Oort
You can also factor it out into two quantities. Eg. x^2+3x+2=0 factors out into (x+1)*(x+2)=0 since one of those quantities must equal zero and it could be either one you set both equal to zero, so it would be x+1=0 and x+2=0. These solve out to x=-1 ans x=-2. (-1)^2+3(-1)+2 goes to 1+-3+2 which proves the x=-1 answer. Then we do the other one, (-2)^2+3(-2)+2 goes to 4+-6+2 which equals zero too. So now we are 100% sure that it is x=-2 and x=-1.
Team 1219: 2009 - Mentor
Unread 16-04-2006, 11:26
in between teams
AKA: Luke Van Oort
Well you distribute w(20-w) to 20w-w^2, then subtract A, so you get
-w^2+20w-A=0. Then you use the quadratic formula so it goes in as
(-20 (+/-) sqrt(400-4(-1)(-A)))/-2 which simplifies to (-20 (+/-) sqrt(400-4A))/-2 you can factor a 4 out of (400-4A) so it becomes 4(100-A). The sqrt of 4 is two, so you get (-20 (+/-) 2 sqrt(100-A))/-2. You can divide the -20 and the 2 by the -2 so your final answer is 10 (+/-) sqrt(100-A).
PS Can someone check me on that? I'm a bit sleepy.
Unread 16-04-2006, 11:59
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
here's my last question, I hope:
A pizza company's research shows that a 25 cent increase in the price of a pizza results in 50 fewer pizzas being sold. The usual price of $15 for a pizza results in sales of 1000 pizzas. The questions are a) Write the algerbraic expression that models the revenue for this situation. and b) what is the optimum Max value?
so far I wrote down on my sheet y=(15+.25x)(1000-50x) This models the revenue so I guess I answered the first question
I know I can solve the second question by using a table and writing down the points of the parabola until I reach the max value, but how do I do it using the algebraic method?
Unread 16-04-2006, 12:03
Circuit Breaker
Let me explain the whole derivation of the quadratic formula.
You have a quadratic equation of the form y = ax^2 + bx + c. You want to find the roots (zeros) of the equation, meaning the values of x at which y is 0. So the equation takes the form ax^2 + bx + c = 0. (Or if the equation already has this form, you can start from here.)
Now, all we have to do is solve for x.
First, you factor the a out of ax^2 + bx, and put the c on the other side:
a[x^2 + (b/a)x] = -c
Next, add b^2/(4a^2) inside the square brackets to complete the square (gotten by dividing b/a by 2 and squaring). Multiply this value by a and add it to the other side to equalize things:
a[x^2 + (b/a)x + b^2/(4a^2)] = b^2/(4a) - c
The contents of the square brackets can now be reduced to [x + b/(2a)]^2, and at the same time we'll make the right side into one fraction:
a[x + b/(2a)]^2 = (b^2 - 4ac)/(4a)
Divide both sides by a:
[x + b/(2a)]^2 = (b^2 - 4ac)/(4a^2)
Take the square root of both sides:
x + b/(2a) = +-sqrt(b^2 - 4ac)/(2a)
Isolate x:
x = -b +-sqrt(b^2 - 4ac)/(2a)
And now you have a formula that can solve for x whenever you have an equation that looks like 0 = ax^2 + bx + c.
Patrick Fairbank
patfairbank.com
Unread 16-04-2006, 12:11
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
grr.....why does it have to be so confusing.....at least to me
Thanks though. I'll try and understand
Unread 16-04-2006, 12:14
Circuit Breaker
The maximum value of a parabola is found right between the two zeros, so the easy way to derive a formula for the x-value of the maximum, if you know the quadratic formula, is to find the average of the two zeros:
x = ([-b + sqrt(b^2 - 4ac)/(2a)] + [-b - sqrt(b^2 - 4ac)/(2a)]) / 2
This reduces to x = -b/(2a).
So to answer the pizza question you need to multiply out your equation into the form y = ax^2 + bx + c, and apply that formula. That should give you the number of price increases.
Patrick Fairbank
patfairbank.com
Unread 16-04-2006, 12:24
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Ok, I think I got the max value question. I do:
15+.25x=0 1000-50x=0
15=-.25x 1000=50x
x=15/(-.25) x=1000/50
x=-60 x=20
now I find the mid point:
(-60+20)/2=-20 which gives me my x value of the vertex. grrrrr...................
Unread 16-04-2006, 12:31
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Maybe you should try Division by zero.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 16-04-2006, 12:32
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
I'm so mad at the moment that I'm debating on whether I should move to Ottawa for the summer and ask my dad's sister to teach me math...and I think I'll go to this after school math thing for the next week because if I don't get this AND I'm going to Atlanta, I'll be a total numbskull when I get back
THANKS FOR ALL THE HELP GUYS. I managed to do something with my homework
Math in careers EricH Career 40 24-06-2008 21:45
**FIRST EMAIL**/Dean's Homework Assignment Beth Sweet FIRST E-Mail Blast Archive 9 10-05-2006 11:31
16 bit math on PIC sciguy125 Programming 17 07-10-2005 02:57
TRIPLE REPLAY ... the consequence for not doing Dean's homework! Natchez FRC Game Design 36 11-05-2005 18:52
New math functions? KVermilion Programming 8 17-01-2005 10:38
