Go to Post "Simple" is about staying within boundaries. - dtengineering [more]
Unread 17-04-2006, 20:30
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Crab Drive
For the past two weeks, I've been thinking up a crab drive for next year. Its very simple, yet does the job. I hope to have the frame of one of the modules at Nationals, so if you want to stop by, I'll be glad to talk to anyone whos interested. O yeh, its going to made out of lexan so you can see the insides! So if you see us in Atlanta come on over and I'll be glad to talk with you. I do have a 2d autocad file of the plates with the bearing pockets and holes ect. if anyone wants it, pm me but I wont have acess to it until next monday. *Granted the robot isnt broken, and I'm not at a match driving*
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 17-04-2006, 21:29
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Re: Crab Drive
sweet i will definatly stop.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 17-04-2006, 21:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Crab Drive
Lexan? That's got to be expensive.
Unread 17-04-2006, 22:16
Joe_Widen's Avatar
Re: Crab Drive
Well we built basically our whole robot out of lexan(polycarbonate), so we have a bunch of scraps. Now, since its basically just so everyone can get the general idea, not function, I'm making out of 1/4" lexan. The hole module is pretty much 3 3*6 pieces of lexan, 2 3*3 pieces, 2 1*3 pieces, a few standoff's, and some angle iron. I have a parts list for one that is strong, made of aluminum, inclueds driveshafts, gear, keys, bearings, and costs less than two andymark 2-speed shifters.
Parts (11.76:1 gear ratio)
Modules
8 Steel Plain Bore 14-1/2 Deg Spur Gear 20 Pitch, 48 Teeth, 2.4" Pitch Diameter, 3/8" Bore
4 Steel Plain Bore 14-1/2 Deg Spur Gear 20 Pitch, 15 Teeth, 0.75" Pitch Dia, 3/8" Bore
12 Steel Ball Bearing Plain Open for 1/2" Shaft Dia, 1-1/2" Od, 7/16" W
8 Steel Ball Bearing Plain Open for 3/8" Shaft Dia, 1-1/8" Od, 3/8" W
1 Fully Keyed Steel Drive Shaft 3/8" Shaft Od, 3/32" Keyway Width, 12" Length
1 Fully Keyed Steel Drive Shaft 1/2" Shaft Od, 1/8" Keyway Width, 24" Length
1 Plain Steel Oversized Key Stock 3/32" X 3/32", 12" Length
1 Plain Steel Oversized Key Stock 1/8" X 1/8", 12" Length
1 Alloy 7075 Aluminum Rectangular Bar 1/4" Thick, 4" Wide, 6' Length
1 Alloy 6061 Aluminum Rectangular Bar 3/16" Thick X 3" Width X 6' Length
1 Alloy 6061 Aluminum Rectangular Bar 1/4" Thick, 5" Width, 3' Length
1 Alloy 6063 Aluminum Round Tube .750" Od, .620" Id, 8' Length
20 Aluminum Female Threaded Hex Standoff 3/8" Hex, 1" Length, 10-32 Screw Size
10 Aluminum Female Threaded Hex Standoff 1/2" Hex, 3" Length, 1/4"-20 Screw Size
(angle iron was at our school)
Total Cost: $654.93
Unread 18-04-2006, 08:23
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
Re: Crab Drive
How complicated is the mechanism? Do just have the legs attached to pneumatic pistons that extend and retract or do you have a motor that rotates like the old style locomotives? I'm very interested on how this works. I will defiantly stop by and see what you've got so far. good luck and I hope to see you soon.
In life, if what we want and what we get isnt what we expected, then thats life, because we cant always get what we want and what we get is never what we expected.
This is our teams offical website, enjoy:http://www.angelfire.com/droid/roswellrobotics/
Unread 18-04-2006, 08:32
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Crab Drive
I had a crazy idea last year to do a crab drive and use 2 AndyMark's on their side; from there I would run chain to each "pod" and the pod would drive the wheels using bevel gears... Chainzilla's counterpart anyone?
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 18-04-2006, 10:54
Joe_Widen's Avatar
Re: Crab Drive
Its actually quite simple. Well if you have a CNC but yeh. Its basically 3 milled plates, standoffs, two plates for holding the sides together and some 3" wheels.
Unread 18-04-2006, 15:32
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Crab Drive
in my initial swerve design, i used a system similar to what you described, with bevel gears and 'remote' gearboxes (dewalts, in my case). in the end, i decided against this and mounted the gear box inside the module because of 'torque-steer'. this thread and this thread offer some pretty good insight into it. obviously, torque steer doesn't preclude this style of design (since its been done successfully before), but it is an additional factor to consider.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 20-04-2006, 23:46
Joe_Widen's Avatar
Re: Crab Drive
Making some revisons, found away to make it cheaper and easier to make. Now there is only one piece to weld and the rest is held togetherby stand offs.
Modules
1 Alloy 6061 Aluminum Rectangular Bar 1/4" Thick, 4" Width, 3' Length
8 Steel Ball Bearing Plain Open for 3/8" Shaft Dia, 1" Od, 5/16" Width
32 Aluminum Female Threaded Hex Standoff 3/8" Hex, 2" Length, 10-32 Screw Size
Total Cost: $479.14
Unread 21-04-2006, 21:50
desi_technology's Avatar
desi_technology desi_technology is offline
AKA: Shahil
FRC #0176 (Aces High)
desi_technology is on a distinguished road
Send a message via AIM to desi_technology
Re: Crab Drive
We did crab drive last year. It worked well after we fine tuned the steering algorithm. The setup we used four cim motors that were vertically mounted on drive modules, which had the custom gearing in them. The robot moved about 9.6 FT/sec. We turned these modules by having two steering modules, one in front and one in back. The modules were powered by window motors, so the front and back drive modules were independently linked, not like traditional crab drive. It was controlled by close loop control using a derivative, which slowed the turning the wheels away from center and speeds up when returning to center, so you maintain accuracy. There where two pots on the steering modules which would turn the wheels in opposite directions so it could turn. If you have any questions about team 176's crab drive just ask?
AWARDS:
2007- Greater Tronoto Winners Thanks To 1114, 2056
2007- Connecticut Finalists
2006- UTC WINNERS, THANKS TO 177,1124
2006- BAE FINALISTS
2005- UTC Woodie Flowers Winner
2005- UTC Engineering Inspiration Award Winner
2005- Long Island Safety Award
2004- BAE Granite State Winners
2004- Nationals Finalist Award in Newton Division
1999- Nation Champions
Visit us at:
www.aceshigh176.org
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
Controls for a Crab Drive Ein Control System 22 26-01-2005 20:31
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
