Re: Using Vex Brain as FRC Coprocessor
6 sonars was just a funny idea I was throwing around before, they'd be spaced out at 60 degree intervals on a full circle so as to allow an updated complete view of the field every half second or so. A few sonars and Sharp sensors might be better, but I know we'd need more than 1 sonar (all the Sharp sensors have too limited a range for what I was thinking of). I think Dave's going to give us all 3 cameras next year from that statement. |
I would really like it if we did have 2 CMUcams, we could find our absolute position on the field (X,Y coords) using stereoscopic vision off the target. It'd be nice if maybe Cognix or NI would donate their packaged vision systems and put them in the KOP... that'd be sweet to have geometric pattern matching, great image processing, and don't forget the high frame rates... (and yes I know this is extrememly expensive, but I can dream can't I? )So, if we were to have a co processor unit for machine vision in the KOP, I'd like it to be DSP based ...hint hint to IFI... but it would be better yet to get one of the vision systems i listed above ![]() Last edited by Qbranch : 18-04-2006 at 17:25. |
Most machine vision systems rquire a very controled setting to work. I dobt we would have any meaningful data by placing these systems on a robot. However 2 cmu's might work.
I know using a Vex as a co-proc would be cool and all, but I think it's wayyy overkill. You can get a top of the line AVR ATMega2561 (pdf warning) for a mere 10% of the price of a vex controller ($16.99 at Digikey). Lets compare the specs.
Vex:
#7
![]() Last edited by Adam Y. : 18-04-2006 at 22:05. |
#8
Just use the PIC18F8722 development board. Or better yet, go for a dsPIC or a Freescale Coldfire processor development board if you really want a serious co processor. The dev. boards have the processors pre soldered, have a power supply, crystal, and have the pins brought out to an array of plated through holes. Also, most include the plugs for connecting your ICD or ICE, your power connection, as well as a ready-to-go DB9 connector to one of the uarts on the processor. Just make sure you heed Adam Y.'s warning: you are opening a whole other can of worms. You'll have to make driver circuits all the output lines that you want to use. You'll also probably want to protect your input lines from ESD in some fashion, and you'll need to write a communications protocol to talk between the two processors, and ... (list continues) ![]() |
#9
This is a very effective means of hand soldering 80 pin TQFP chips like the 18F8520. I have used it successfully on 3 boards so far. Check it out with a microscope before you power the board on though. I made a IR interrupter for the ball sucker upper on our robot using a PIC18F88. It only produced a square wave, but my mentors wanted to see how to make a PCB using toner from a laser printer. It worked very well, but this could easily have been done using a COTS sensor and the RC. (I also needed to brush up on my assembly). I agree that it would be difficult to communicate with a coprocessor because you do not have access to the RC's SPI or I^2C and you need the USART for the video camera. |
