Go to Post Compact gearboxes are a wonderful thing. - Cothron Theiss [more]
Unread 17-04-2006, 20:31
CircularLogic CircularLogic is offline
FRC #1546 (Chaos Inc)
CircularLogic will become famous soon enoughCircularLogic will become famous soon enough
Programming question
A couple of weeks ago, I wrote some code just to test out motor direction and then from there decided to write "real" code in the same file. Because easyC does not allow me to edit the text, I couldnt find a way to comment the test section of the code so I just made it an invalid while loop. (while(1==0)).
So when I ran the code, I noticed there was a rhythmic beep and silence pattern which corresponded to the same type of rhythmic motor control and lack of control. I figured out that it was the invalid while loop that was doing it.
Now I am experiencing a similar problem, but the rhythm of no control is much shorter. The only part of the code that would ever not be operation is a fairly large if statement. Is it possible for that if statement to cause a break in the code? Or could it have something to do with an undefinied variable?
#include "UserAPI.h"
int a = 0;
int b = 0;
int c = 0;
void main ( void )
while ( 1 )
MotorRcControl ( 0 , 2 , 3 , 0 ) ;
MotorRcControl ( 0 , 3 , 4 , 1 ) ;
MotorRcControl ( 0 , 6 , 1 , 1 ) ;
a = GetRxInput ( 1 , 5 ) ;
if ( a>127 )
SetPWM ( 2 , 160 ) ;
PrintToScreen ( "154\n" ) ;
else
if ( a<127 )
SetPWM ( 2 , 90 ) ;
PrintToScreen ( "100\n" ) ;
else
SetPWM ( 2 , 127 ) ;
PrintToScreen ( "127\n" ) ;
b = GetRxInput ( 1 , 6 ) ;
if ( b>127 )
SetPWM ( 1 , 144 ) ;
else
if ( b<127 )
SetPWM ( 1 , 110 ) ;
else
SetPWM ( 1 , 127 ) ;
Team 1546 Chaos Incorporated
2005- SBPLI Rookie All Stars
2006- SBPLI Sportsmanship award.
Gotta hand it to the straight line autonomous mode, the most effective defense out there.
Proud beyond belief of the accomplishments of the second year, 20th ranked, 6 wins and 6 losses Chaos Incorporated.
Unread 17-04-2006, 21:52
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Programming question
There is a way to comment out code in EasyC, right click on an item in the flowchart and select "comment out". Try seeing if the actual comment out takes care of things.
VEX programming Gene F Programming 14 08-08-2006 22:21
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
have a question to ask about Double Solenoids to one spike programming davelu Programming 3 22-02-2005 09:52
General programming question mikesown Programming 1 07-02-2005 16:09
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
