Go to Post There is no shame in admitting someone is better than you at something doesn't make them a better person just means they have skill you haven't figured out yet. The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 17-04-2006, 22:16
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: Crab Drive
Well we built basically our whole robot out of lexan(polycarbonate), so we have a bunch of scraps. Now, since its basically just so everyone can get the general idea, not function, I'm making out of 1/4" lexan. The hole module is pretty much 3 3*6 pieces of lexan, 2 3*3 pieces, 2 1*3 pieces, a few standoff's, and some angle iron. I have a parts list for one that is strong, made of aluminum, inclueds driveshafts, gear, keys, bearings, and costs less than two andymark 2-speed shifters.
Parts (11.76:1 gear ratio)
Modules
8 Steel Plain Bore 14-1/2 Deg Spur Gear 20 Pitch, 48 Teeth, 2.4" Pitch Diameter, 3/8" Bore
4 Steel Plain Bore 14-1/2 Deg Spur Gear 20 Pitch, 15 Teeth, 0.75" Pitch Dia, 3/8" Bore
12 Steel Ball Bearing Plain Open for 1/2" Shaft Dia, 1-1/2" Od, 7/16" W
8 Steel Ball Bearing Plain Open for 3/8" Shaft Dia, 1-1/8" Od, 3/8" W
1 Fully Keyed Steel Drive Shaft 3/8" Shaft Od, 3/32" Keyway Width, 12" Length
1 Fully Keyed Steel Drive Shaft 1/2" Shaft Od, 1/8" Keyway Width, 24" Length
1 Plain Steel Oversized Key Stock 3/32" X 3/32", 12" Length
1 Plain Steel Oversized Key Stock 1/8" X 1/8", 12" Length
1 Alloy 7075 Aluminum Rectangular Bar 1/4" Thick, 4" Wide, 6' Length
1 Alloy 6061 Aluminum Rectangular Bar 3/16" Thick X 3" Width X 6' Length
1 Alloy 6061 Aluminum Rectangular Bar 1/4" Thick, 5" Width, 3' Length
1 Alloy 6063 Aluminum Round Tube .750" Od, .620" Id, 8' Length
20 Aluminum Female Threaded Hex Standoff 3/8" Hex, 1" Length, 10-32 Screw Size
10 Aluminum Female Threaded Hex Standoff 1/2" Hex, 3" Length, 1/4"-20 Screw Size
(angle iron was at our school)
Total Cost: $654.93
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
Controls for a Crab Drive Ein Control System 22 26-01-2005 20:31
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
