Go to Post On a lighter note, I know my team's happy that in our Rookie Year we built the sexiest robot in the world and got the Imagery Award at Nationals :D - Snappel328 [more]
Unread 18-04-2006, 14:36
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
What Victor for VEX Controller?
Curious if anyone has connected a Victor to a VEX controller yet.
Looks to me by the specs, we can use any victors from IFI:
http://www.ifirobotics.com/speed-con...on-guide.shtml
Anyone tried yet?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 18-04-2006, 15:24
Billfred's Avatar
Billfred Billfred is offline
Re: What Victor for VEX Controller?
Haven't tried it yet myself (probably because I don't own a Victor), but IFI (or VexLabs--toMAYto, toMAHto) seems to indicate that you're alright:
http://www.vexlabs.com/forum/viewtopic.php?t=86
Unread 18-04-2006, 18:34
Gdeaver Gdeaver is offline
FRC #1640
Yes , they work and your team may have some old 883's laying around. RC car ESC will also work . Check the voltage rating of the RC ESC.
Unread 25-04-2006, 19:30
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Any IFI Victor will work with Vex.
When prototyping our FRC shooter this year, we ran a CIM with an 884 Victor through the Vex controller and used the online terminal code to adjust the pwm output off the PC in real time. Here's a picture during the prototype's construction, and no, the Vex controller is not just posing for this picture.
Standard hobby electronic speed controllers will also work.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 25-04-2006, 20:22
in between teams
AKA: Luke Van Oort
You know, assuming it's durable, I would be suprised to see VeX popping up in a combat robotics leagure sometime soon. The controller/radio combo is pretty cheap for its usability and you could then spend your money on big dog speed controllers like the HV and Thor victors, as well as the Victor 885, and some of the massive speed controllers that measure their maximum sustained amperages in the hundreds.
Team 1219: 2009 - Mentor
Unread 25-04-2006, 21:00
FRC #1640
One thing to keep in mind if your going to start using big motors and victors with the VEX module is that the Vex radios are low frequency analog. High rpm can motors can put out allot of RF noise that can screw up the radios. A couple of caps can cut down on the noise. Also, REMEMBER TO PUT SOME FUSES ON THIS STUFF. The other thing to remember is NICAD's don't take abuse as well as gel cells.
Temperature sensitive controller? maybe 8.2 V related? ericand Programming 6 10-03-2006 12:53
Direct control of a Servo or Speed Controller Schmitty! National Instruments LabVIEW and Data Acquisition 3 06-03-2006 13:53
Mini-Me robot arm controller Andrew Schuetze Control System 7 19-10-2005 11:07
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
