Go to Post Go with a Big Block. The torque is awesome and you cant beat the sound of a built Big Block with a high lift cam and some open headers. A blower would be a nice addition as well. Good luck getting past the inspector. - GBK [more]
Unread 18-04-2006, 20:46
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Vex Wishlist?
Originally Posted by gdo
a "y" connector would be nice to allow more batteries to be used.
also I would like to see some improved motors (in torque and speed)
Y-cables are easy to make. If you go to RadioShack and buy two of their $3.49 7.2v battery connecter repair kits and some heat shrink tubing, you can make your own Y-cables for less than $10 each. Just make sure you connect the two batteries in parallel and NOT in series. I am planning on making some of these Y-cables soon so that my future Vex robots can run for longer periods of time at public demonstrations.
You can also make smaller rotation sensors by using one of the line following sensors and a high contrast disk like this. Of course you can make the disk a lot smaller and build it into the side of one of the wheels on your robot.
Also, if used correctly, the chain in the Vex kits is plenty strong enough. I was able to use a single loop of Vex chain to power the double stage "space elevator" Vex robot that I built last fall. I never really had any problems with breaking strength, even with three mini-tetras at one-pound each on the end of a 14-inch arm, extended perpendicular to the ground, while trying to lift both elevator stages. If you find the chain breaking too much, try re-gearing your mechanism. Sure, it might become slower, but you have to make some trade-offs to make a reliable robot.
EDIT: Also, I have never had any problems with the motor clutches either. Again, it is all how to apply them. The same drivetrain for the "space elevator" robot in the above link was only powered by two motors. That was a very heavy Vex robot, and it was still powered with a 1:1 gear ratio. Sure, I had to swap out the four end wheels for omni wheels to make it turn easier, but the end result proved more efficient and it was drove better.
Vex is not a "Here is a completed solution for you" kind of program. Vex is about using the resources you have and pushing the envelope on what you can do with them. Sure, asking for some new parts from IFI is fine, but asking for them to design everything you can ever need is a but too much.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-04-2006, 21:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Vex Wishlist?
I'd like to see connector bodies made available, to make extra cables for whatever sensor you like...
Don
Unread 18-04-2006, 22:45
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
Re: Vex Wishlist?
I'd like to see them offer Vex earrings - I'm havig a heck of a time making tiny little Vex robot earrings to wear in Atlanta!
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 20-04-2006, 11:08
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Re: Vex Wishlist?
I was wondering where to get those earings myself. I almost snatched one of those off the ear of Jeff Rosen the announcer for the matches. Ok.. the ear ring issue aside. I would like to see some new items introduced to facilitate customization by users. There are other things that could be changed in the starter kit, that could almost be done with no increase in cost. These include:
  1. Provide a source to buy the keyed PWM male connectors to facilitate interfacing your own sensors, pots, leds, etc.
  2. Make available additional technical info on the TX/RX ports for customization.
  3. Go exclusively to the higher quality screws offered at Vexlabs - I know its more cost, but I think its worth it.
  4. Throw in a few of those alternate size nylon spacers on the Vexlabs website.
  5. Get rid of those near useless hex L-keys and put in the correct size, good quality keys.
  6. Include less kep nuts and more nyloc nuts.
  7. Provide a better method to secure the receiver antenna other than that anorexic plastic straw.
  8. Omit the limit switches, bump switches and the 2 battery enclosures and include the rechargable power pack kit. I mean who uses these battery enclousres past the first set of batteries you burn through anyway.
  9. Include a 12" PWM extension in lieu of the 6".
  10. Include a nylon insert into the motor & servo screw mounts to keep screws from vibrating out. Loctite works just as good, but why bother.
I've got a few other nit-picks for the kit but I think its a well thought out product. For additional accessories to be developed, maybe Bevel gears, a rack to go with the existing spur gears, a differential, a gyro. Most of these items however can be done by users with a little know how and some determination. They would however not be legal in an FVC competition unless they were available through Vexlabs.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 20-04-2006, 11:54
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
Re: Vex Wishlist?
A variety of metal pieces would be nice. I'm still afraid to cut because I keep modifying it and I am afraid that the pieces I cut won't fit into the new bot. I plan on buying the metal and hardware kit though.
It would also be nice to see some sprockets and more wheels in the kit.
Unread 20-04-2006, 21:33
KINGOFCLUBS454's Avatar
KINGOFCLUBS454 KINGOFCLUBS454 is offline
Creamer Connoisseur
AKA: Andrew
FRC #0357 (Royal Assault) VRC #KTOR (Knights of the Olde Robotics)
KINGOFCLUBS454 has a spectacular aura aboutKINGOFCLUBS454 has a spectacular aura aboutKINGOFCLUBS454 has a spectacular aura about
Send a message via AIM to KINGOFCLUBS454
Re: Vex Wishlist?
Originally Posted by Donut
I don't think anyone would object to mecanum wheels making an appearance. If only the Navy didn't own the patent...
Actually, the navy sold the patent to a company called Airtrax. They are currently using the design to make comercial and military vehicles.
PATENTed
VRCC KTOR - Captain
FRC357 - Alumni
FRC2023, FTC508 - Mentor
FLL5297 -Mentor
Unread 21-04-2006, 01:42
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Vex Wishlist?
They sold it to 2 companies, the second one isn't doing nearly as well though. I heard the patent only cost around $2500 for each company. Airtrax is making forklifts with them (their's a video available), the other company was using them to make aircraft luggage loaders.
Maybe someone can convince them to manufacture just mecanum wheels commercially?
And I have a question, why is the Vex power pack battery heavier than the standard battery holder with 6 NIMH AA's, even though the 6 NIMH hold more power?
Unread 21-04-2006, 14:27
Re: Vex Wishlist?
... the other company was using them to make aircraft luggage loaders.
That's where 330 originally got the idea--At LAX in '03, we'd just returned from Championship and saw these wierd wheels on the cargo crate unloader. We started plotting immediately.
Innovation First acquires Vex from Radio Shack Brandon Martus General Forum 58 20-04-2006 17:32
Radio Shack to discontinue VEX? jeffmorris General Forum 52 24-03-2006 16:33
Vex and Lego Cyber Punk 234 General Forum 3 03-12-2005 22:50
Milwaukee VEX League Kevin Kolodziej Off-Season Events 7 05-11-2005 17:58
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
