#16
Re: Can Wireless Video Cameras Be Used?
If on board cameras to internal media were mounted during competition matches, they should have been included in your robot weight. No matter what wireless frequency or modulation is used, the system must be cleared with FIRST before the competition. AND the main battery and the backup battery can be the only electrical power source on the robot.
<R51> The only legal main source of electrical energy on the robot is the 12VDC non-spillable lead acid battery provided in the Kit of Parts. That 12V battery is the Exide type EX18-12. The ES18-12 battery, purchased through your local Exide supplier as a spare, is identical and may also be used. You may use other equivalent type 12V batteries, but only during the Thursday practice rounds. The 7.2v “backup” battery is considered an integral part of the Robot Controller, and may not be used for any other purpose. |
#18
If an on-board camera, wireless or otherwise, is used to record and later promote a FIRST event, then where is harm or foul in it having a self contained battery? Those batteries would not be an adjunct to "the only legal main source of electrical energy." The rule is about integral parts of the robot; the ones that provide power and have direct impact on the competition. It is certainly a stretch to apply it to anything else. The forward to the General Design & Safety Rules says: “When reading these Rules, please use technical common sense (engineering thinking) rather than a lawyer’s interpretation. Try to understand the reasoning behind a rule.” We could have them remove the AA batteries and use a custom designed supply that draws power from the the Exide. But what would be the purpose in that other than to make them lawyer their way into getting it done? It would, in fact, be contrary to this engineer's thinking in that it adds a frivolous layer of complexity. I can see how we'd not want to see a bunch of C cells duct taped together to power some non-functional neon under glows; but to prohibit a few AAs in a palm sized DVD recorder makes no sense at all. Last edited by Jack Jones : 04-04-2006 at 08:33. |
#19
Jack and Dave,
I brought this up simply because it was interpreted that way in the past. Cameras being non-functional decorations, that is. I personally would love to see more video coming from a robot camera for crowd appeal. Often cameras are used in kit form and the power supply is pretty suspect. It is still necessary for inspector to see how the camera is mounted on the robot. As you know, parts that are not securely attached become missiles in a defensive game. So we need to know that parts on robots are securely attached and will not injure participants or damage other robots. Consumer grade cameras are now often supplied with Nickel Metal Hydride batteries which pose a serious fire threat if damaged and exposed to the air. For that reason, I would defend the single supply rule in most cases. I know this sounds a little strange, but why would anyone want to subject an expensive component to the abuse suffered during a normal match if it's only purpose was to bring back "cool" pictures. Recording media that uses spinning mechanical systems (video heads and hard disks) as part of the record process, suffer from centrifugal force issues that affect the recording process. |
#22
An on-board camera with it's own on-board power source and on-board internal storage media could be "interpreted" as a robot "decoration".
I just think that, at the current time, this "creativity" hasn't been well-thought out by FIRST, and untill a real rule is put in place which comprehends all the scenarios, it should not be allowed. After all, what's the purpose of an on-board camera? a) for fun in the highlights video? b) For aiming strategy for the 3-point goal? In either case, this can all be done on the practice field or during practice rounds, not full competitive matches..... Obviously, if FIRST really "chews" on this problem, then a) the weight of this on-board device must be included in the robot b) the device will need to be inspected to ensure that it really is not providing feedback to the drivers during the match.... By the way, there's a separate thread on this forum about NOT changing the on-field video screen except for a field overview view (no close-ups, no on-board views, no tops-down views).....Then how come a football game switches camera angles about every 7 seconds! Can you say "Pandora's Box"......? Just my humble opinion as a videographer. |
#23
The issue of having a camera on the robot has been extensively discussed so here's my comment:
The question is a good one and you may be suprised at the answer. What is the answer? - You may never know unless you ask! By asking I mean going to the official Q&A fora and state all the parameters of your question! I may have missed something but I just looked at the site and there is not a single question concerning this issue so it just begs to be asked. Teams? Ron Webb Head Ref Atlanta |
#24
<UPDATE> The question has been asked!.
Team 1425 and Team 8 requested, and eventually received permission to use cameras recording to SD memory cards. The robot's point of view can be very interesting. Last edited by ericand : 19-04-2006 at 17:21. Reason: UPDATE |
#25
Eric,
If you have the videos I'd love to see them. Send them to me at work if possible. Ellery |
#26
Is the FIRST QA forum down? How do we ask?
I got the QA Forum information for our team and logged in to ask my question in the Robot rules section. The forum let me start a new thread and seemed to accept my question. However, the question never showed up in the forum. Am I missing something? Does the question need to be reviewed by a moderator before showing up? Could there be some problem with my post such that the forum is silently rejecting it? Quote:
#27
We cleared a camera- wirless system at The West Michigan Regional. The team member who set it up asked the a/v crew if they would access to the feed. Over night this friend of mine put a video together, putting three camera views on one screen in sink with each other for the launch break on Saturday.
#28
If you want to insure that your question gets answered - please go to the moderated section of the fora and there is a thread for questions for the Championships.
Ron |
#30
This reply is understandable, but a bit disapointing, since there seems to be some precedent for allowing such self powered decorations in the past. Modifying the camera's power supply to get what it needs from the onboard 12V battery makes the rig more complex, more prone to failure, less reusable post competition, and less portable. I was hoping for some answer that was in line with this note from the 2006_Welcome_to_Robot_Inspection-Rev_D.pdf (page 5): Energy Sources: No energy sources are permitted other than a single Exide ES/EX18-12 battery, 7.2V backup battery, compressed air supplied by the Thomas compressor (either on or off the robot) and stored within the pneumatics (all components from the kit), dropping of robot’s center of gravity and "safe" deformation of robot components (e.g. springs). No flywheels. Teams may use additional batteries to provide power for decorations but the batteries and circuitry must be completely isolated (electrically) from the robot control circuitry. In addition, the Exide battery must be securely attached within the robot. not withstanding the fact that the same document states just the opposite on page 6: Decorations: Cannot affect outcome of match, cannot broadcast using wireless communication without clearance from FIRST Engineering, cannot employ 900MHz cameras, cannot use electrical power unless drawn from Exide 12V battery via either 20A or 30A circuit breaker Any way, we will have the parts in Atlanta and time will tell if we can configure them acceptably for use during the competition. |
| 1604 Harmony Hurricanes promo video | Barry Bonzack | Robot Showcase | 11 | 04-03-2006 18:56 |
| Video Cameras | Ian Curtis | Chit-Chat | 7 | 27-06-2005 12:11 |
| Video: Cyber Blue 234 Late Night Programming Video | JAH | Robot Showcase | 6 | 13-03-2005 00:34 |
| GizMOE Revealed - NEW VIDEO from team 365!! | SuperJake | Robot Showcase | 14 | 25-03-2004 22:35 |
| Good video footage | miketwalker | General Forum | 0 | 28-03-2002 17:14 |
