#9
Re: Crab Drive
Making some revisons, found away to make it cheaper and easier to make. Now there is only one piece to weld and the rest is held togetherby stand offs.
Parts (11.76:1 gear ratio) Modules 1 Alloy 6061 Aluminum Rectangular Bar 1/4" Thick, 4" Width, 3' Length 1 Alloy 6061 Aluminum Rectangular Bar 3/16" Thick X 3" Width X 6' Length 8 Steel Ball Bearing Plain Open for 3/8" Shaft Dia, 1" Od, 5/16" Width 12 Steel Ball Bearing Plain Open for 1/2" Shaft Dia, 1-1/2" Od, 7/16" W 1 Fully Keyed Steel Drive Shaft 1/2" Shaft Od, 1/8" Keyway Width, 24" Length 1 Fully Keyed Steel Drive Shaft 3/8" Shaft Od, 3/32" Keyway Width, 12" Length 1 Plain Steel Oversized Key Stock 3/32" X 3/32", 12" Length 1 Plain Steel Oversized Key Stock 1/8" X 1/8", 12" Length 8 Steel Plain Bore 14-1/2 Deg Spur Gear 20 Pitch, 48 Teeth, 2.4" Pitch Diameter, 3/8" Bore 4 Steel Plain Bore 14-1/2 Deg Spur Gear 20 Pitch, 15 Teeth, 0.75" Pitch Dia, 3/8" Bore 32 Aluminum Female Threaded Hex Standoff 3/8" Hex, 2" Length, 10-32 Screw Size Total Cost: $479.14 |
| Crab drive question | Tazlikesrobots | Technical Discussion | 13 | 31-07-2005 20:51 |
| If you could change one thing.... | Koko Ed | General Forum | 48 | 31-03-2005 19:23 |
| Controls for a Crab Drive | Ein | Control System | 22 | 26-01-2005 20:31 |
| rotation of body of crab drive robots | michael_obrien | Technical Discussion | 6 | 22-10-2003 19:32 |
| how does crab drive work? | Soukup | Technical Discussion | 13 | 25-04-2003 11:31 |
