Go to Post A dedicated team is a happy team. - sgreco [more]
Unread 22-04-2006, 10:04
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Inexpensive crab module?
I'm looking to design a crab drive robot over the summer... on my own budget. That budget? A McDonald's check... *sigh* So... here's my question. Can somebody design a relatively cheap and innexpensive crab drive module? Or atleast give me ideas on what to use. The entire robot will be 28X28. I'll be using 4" diameter wheels. I don't know what kind of wheels to use. If anyone can provide me a link to innexpensive wheels that'd be great. Also be using drill motors geared down for the drive... b/c I can get them very cheap. So... if anyone needs any more information then ask. I know I probably didn't provide enough info but it's the best I can do on what I know.
PS - I would ask some of the engineers on my team to help but they are mostly on vacation for a few months from robotics.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 22-04-2006, 10:20
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: Innexpensive crab module?
You say that you will be using drill motors. Will you also be using the drill transmissions?
If you are you may be able to direct drive the 4" wheels to the drill output and save the cost of chain/belt/pulley/gears.
A chunt of plastic such as Delrin or Nylon can may a good inexpensive pivot/thrust bearing for your crab module and it is much cheaper than roller bearings.
Matt B.
Unread 22-04-2006, 10:57
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
i think wildstang's crab drive from 2003 is a good bast to copy from it had 4 delrin bushings around a bottom plate that had some pillow blocks the wheel and a transmition and the weight was supported from the top by what i believed to be something like a lazy Susan bearing, not good for side load but it didn't matter with the delrin at the base. i wish i could find the pictures of it but it looks like nobody has tagged them in CD media yet im shure Raul Could elaborate further.
Unread 22-04-2006, 11:18
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
You can find many pictures in our gallery. Here are some albums that have some shots of the modules and mounting points. If you want more information, I would suggest contacting Raul. He'll be able to give you more details than I could.
http://www.wildstang.org/gallery2/v/..._Construction/
http://www.wildstang.org/gallery2/v/...3_Robot_Proto/
(Note that in the side-by-side album, you can see our mythical stacker that was removed early on at Great Lakes)
Unread 22-04-2006, 11:55
Go VOLS!!
AKA: Budda648
no team (QC Elite)
So... to use Nylon... I would put the Nylon between the frame and the module to reduce friction? And then a bearing on the shaft between the shaft and frame. I think I understand what you're trying to say. Anyone know where I could get some of this stuff?
Do The Tyler!
Unread 22-04-2006, 12:49
AKA: Ty
mcmastercarr.com in the plastics section.
Unread 22-04-2006, 13:18
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Does anyone know where to get a microcontroller and operator interface/radio for cheap? Needs analog outputs and C programability. I found one... but I just wanna shop around before commiting.
Do The Tyler!
Unread 22-04-2006, 14:26
in between teams
AKA: Luke Van Oort
RobotCombat is a great place to look for anything related to robotics.
Team 1219: 2009 - Mentor
Unread 22-04-2006, 16:49
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Thanks... I've been to this site multiple times.
Question: If I buy an R/C transmitter and receiver... How do I incorporate that with the controller? And also... how would I go about making my own transmitter? With joysticks and all... I know how to do it with the FRC operator interface but what about with a different one?
Do The Tyler!
Unread 22-04-2006, 22:09
in between teams
AKA: Luke Van Oort
I don't know, you should probably try Greg Needel, he might know.
Unread 23-04-2006, 00:53
Go VOLS!!
AKA: Budda648
no team (QC Elite)
I PMed Greg.
I also found a transmitter/reciever package from RobotMarketplace but would prefer to make one identical to ours from this year and the past couple of years.
I'm using the MTJPRO11a microcontroller from MrRobot.com.
Do The Tyler!
Unread 23-04-2006, 11:48
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
The best deal on a combination radio controller and C programmable microcontroller right now is the VEX kits selling for $150 at radioshack.
Zan Hecht
Unread 23-04-2006, 14:18
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Will the VEX kit radio and microcontroller work for a bigger robot? I have a VEX kit ordered... but for a VEX robot.
Do The Tyler!
Unread 23-04-2006, 14:51
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Inexpensive crab module?
You can use the Vex transmitter/receiver/microcontroller to drive Victor speed-controllers, which can then be used in a manner similar to FRC to drive motors on a big robot.
-JV
Unread 23-04-2006, 19:35
Go VOLS!!
AKA: Budda648
no team (QC Elite)
-JV
Hm... how many Victors can I run with one VEX microcontroller?
Do The Tyler!
New Module system Astronouth7303 FIRST-related Organizations 1 25-05-2005 17:30
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
