Re: DISTANT shooter BOTS
1523 had a great long range shooter. They consistantly made shots at and behind half-court at the Florida Regional.
648's robot can shoot accurately from halfcourt and a little behond. It's just that little nudge on the dial to get it to fire at the right speed that makes it hard.
Since you didn't specify top goal shooters, I'll throw in the tidbit that we can score the bottom goal from distances longer than the field.
I would also like to mention 1280, which has made shots from half field and farther, both in and out of auto mode. |
normally i dont boast about my team, but in this case....
we can shoot from 8 feet behind the halfcourt line (halfcourt + 8 ft)...we are also able to shoot from all three starting positions, accurately |
Ive heard 303 can make them from extremely far back behind the half court line
#7
On a side note, how many of these robots stayed under the 12 m/s rule?
#8
Two distant shooters that stand out in my mind are 1219 and 522. Both scored pretty consistently from half-court or so.
#10
The best long-range shooter I saw at Florida was 1523. They made shots from so far it boggled the mind. And since they used a catapult to shoot, they were incredibly consistent.
At Lone Star, 148 had amazing range. Couple that with their holonomic drive train, and they were really tough to stop. |
#11
^Not true. I haven't heard of many regionals actaully checking for ball speed. I am not saying that any of these teams shoot over 12m/s.
I saw 832 (Roswell Robotics) shoot from a pretty far distance on the practice field. 1261 (Peachtree Ridge) hit some pretty far shots too. |
#13
They will check you if it is in any question. If you start shooting from 1/2 court and are nailing them consistently someone will question it whether it is a ref or another team. At great Lakes they just abonded it but 1114 was questioned right after they won in the semi finals and moved to the finals.
A couple of teams were tested at Detroit from my view from our pits and i am not to sure anyone was checked at Western Michigan. But just note that if someone questions it I am pretty sure that you will be tested. ![]() |
#14
Team 341 and 103, if i remember right were able to shot from the far very precisely. They most of the times used there autonomous to shot from the far and it worked pretty well.
| Newton Discussion | AcesPease | Championship Event | 165 | 03-05-2006 20:52 |
| Ideal Alliance Structure | Lil' Lavery | Rules/Strategy | 34 | 22-04-2006 18:21 |
| Shooter Help | Bongle | General Forum | 15 | 29-03-2006 00:36 |
| 2-Speed Shooter Gearbox | JVN | Technical Discussion | 4 | 08-02-2006 13:52 |
| Shielding the Shooter | WebWader125 | Rules/Strategy | 10 | 05-02-2006 20:05 |
