Go to Post Wow, 3 people able to draw their designs using text in a script processor program. I guess I wasted my time learning all that CAD software - Gary Dillard [more]
Unread 22-04-2006, 16:20
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Re: DISTANT shooter BOTS
They will check you if it is in any question. If you start shooting from 1/2 court and are nailing them consistently someone will question it whether it is a ref or another team. At great Lakes they just abonded it but 1114 was questioned right after they won in the semi finals and moved to the finals.
A couple of teams were tested at Detroit from my view from our pits and i am not to sure anyone was checked at Western Michigan. But just note that if someone questions it I am pretty sure that you will be tested.
-Josh Murphy-
Unread 22-04-2006, 17:00
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
Originally Posted by Lil' Lavery
1261 was the most effective perimeter shooter I saw first hand, but 1610 was not far behind.
Thanks....The kids wanted the bot to be able to shoot from
different distances...during testing we accually had it shooting from
mid field.
Come by and see us at our pit and say hi.
Unread 22-04-2006, 17:32
AKA: Dr. Brooks
no team (WRRF)
Originally Posted by s_forbes
On a side note, how many of these robots stayed under the 12 m/s rule?
Team 1280 uses speed regulation on their ball shooting wheel.
It is not possible for the operators to set the wheel speed to
exceed 12 m/sec. A light on the OI informs them that the
robot is "out of range" with the speed limit activated.
With backspin, as 1280 uses, it is possible to center a shot in the 3
point goal from behind mid field. Without backspin, the maximum
distance would be a bit less.
If we must question the shooting speed of longer distance shooters
who have worked very hard to implement backspin, wheel speed
regulation, and a good targeting system; perhaps we should also
question the shooting speed of a close distance shooter that shoots
at rates exceeding 2 balls per second without wheel speed
regulation. Excessive shooting speed is not as visible to
someone watching the field in this case, but it constitutes just as
much of a competitive advantage, if not more.
Making a shot from mid field, with backspin, is not evidence
of excessive shooting speed. It is evidence of shooting just
short of the 12 m/sec speed limit...
Unread 22-04-2006, 17:36
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
mid field.
I would, but sadly I won't be in Atlanta next weekend
Originally Posted by santosh
I saw 832 (Roswell Robotics) shoot from a pretty far distance on the practice field.
At least by the end of the weekend, 832 had become a ramp shooter though.
Unread 22-04-2006, 18:08
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
I see an advantage of having a high shooting velocity for the short distance shooters only in that it is easier for them to maintain the speed necessary to get the balls into the goal.
That being said it seems that no one would be exceeding the maximum balls per second scored when limited by the 12m/s rule because that would allow around 60 balls per second. However exceeding the speed does give teams a bit of advantage as they would not have to calculate the correct speed to shoot the balls at a lesser velocity but closer together.
I agree that the rules should be applied across the board, but typically it seems that a teams competitive advantage from their ability to score a lot of goals with a one shot at a time system is much more limited by their feeding mechanism speed than their shooter speed.
Unread 22-04-2006, 19:04
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
^Not true. I haven't heard of many regionals actaully checking for ball speed. I am not saying that any of these teams shoot over 12m/s.
I saw 832 (Roswell Robotics) shoot from a pretty far distance on the practice field. 1261 (Peachtree Ridge) hit some pretty far shots too.
I was happy to see that the regional that I was at, the Finger Lakes Regional, actually checked all of the robots for ball speed. there were only 30 teams, so it was not hard to do this for every robot.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 22-04-2006, 19:13
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
Team 341 and 103, if i remember right were able to shot from the far very precisely. They most of the times used there autonomous to shot from the far and it worked pretty well.
Unread 23-04-2006, 12:31
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I don't think its possible to make a goal much past half court if you stay under 12m/s.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 23-04-2006, 13:03
av11d's Avatar
av11d av11d is offline
College Bum
no team ((Team 75 Alum -- Capt 05 & 06))
av11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to behold
I don't recall any teams being able to shoot far... and accurate. Although I consider accuracy making 3/4 of a robot's balls in.
As far as testing speeds at regionals, we actually had our shooter speed tested. In one match we made some balls from beyond half-court. Afterwards the head ref came over and requested that we go have our ball speeds checked.
It just makes sense to shoot up close.
2003 Animator and FIRST newbie
2004 HP, Animator & Programmer
2005 Team Captain, Arm Operator & Animator
2006 Team Captain
2006 BOSTON ENGINEERING INSPIRATION WINNERS
2006 NJ ENGINEERING INSPIRATION WINNERS
2006 BOSTON AVA WINNERS
2005 DUEL ON THE DELAWARE CHAMPS w/ 222 & 1721
2005 BRUNSWICK ERUPTION IV CHAMPS w/ 358 & 369
Unread 23-04-2006, 14:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
with backspin and other factors it is. The MUZZLE veolocity is 12 m/s, not the ball velocity (ie, if your robot is moving in the same vector as the direction you fire, the ball will end up with a speed > 12 m/s but the velocity it exits with relation to the "muzzle" will be <12 m/s).
Sorry if I confused anyone...
Unread 23-04-2006, 19:37
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Back on topic.
I have to mention 20 again. Not only can they hit from a distance they are accurate and have one of the most beatifully designed shooters I have seen. Also they were happy to talk about how they reached their design.
126 can also close to half court. They aren't as accurate but they shoot fast.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 24-04-2006, 11:58
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
107 can shoot from about half court, I think. They usually do this late in the match, after loading up. It was awesome to watch them in the finals. You thought they could only go on the ramp, then these balls start coming from no where. You look and it's 107 shooting from just past mid court.
Unread 29-04-2006, 21:02
edboy's Avatar
edboy edboy is offline
Plays well with others
AKA: Patrick
FRC #1261 (Robolions)
edboy is on a distinguished road
about the 12 m/s rule
we (1261) tried to radar our shooter with a gun, but to no success
since the balls dont have reflective surfaces, the gun couldn't pick them up
we never figured out if we were over, and wanted to observe gracious professionalism, but couldn't get a radar check, either at regionals or nationals
one person suggested that maybe FIRST figured out they couldn't clock it, at least easily, and decided to just let it go unless there was an appeal
Unread 29-04-2006, 21:18
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Enforcement of the muzzle velocity rule varied somewhat from event to event. An earlier post explains how we handled it in St. Louis.
Richard Wallace
since 2003
Unread 30-04-2006, 09:19
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
we (1261)... couldn't get a radar check, either at regionals or nationals ...
I can't speak for the events you were at, but at the three regionals I worked all you had to do was ask and the inspectors would check your shooter speed.
During build season Team 103 tried to use a sports radar gun, but like most got too much interference from the shooting mechanism, so we built our own time-of-flight speedometer to calibrate our shooter. We actually were rather worried that we were over the limit because of the range we were getting (past half-field), and needed the speed check to make sure we were legal (we were). As mentioned earlier and elsewhere, the lift generated by back-spin extends your range quite a bit! FWIW, we shot at 11.4 ~ 11.7 m/s - except for when the shooter got cranky and they just dribbled out...
Pete Kieselbach
Newton Discussion AcesPease Championship Event 165 03-05-2006 20:52
Ideal Alliance Structure Lil' Lavery Rules/Strategy 34 22-04-2006 18:21
Shooter Help Bongle General Forum 15 29-03-2006 00:36
2-Speed Shooter Gearbox JVN Technical Discussion 4 08-02-2006 13:52
Shielding the Shooter WebWader125 Rules/Strategy 10 05-02-2006 20:05
