Re: Will the car make it in?
I agree with what you said, it can be done. It would also be rough on the drive line of the car, although not as rough as exiting the truck at speed. A sports car isn't a necessity though, it can be done with almost any vehicle. Also don't forget that as soon as the car hits the ramp it will lose some momentum due to the upward angle of the ramp, not enough to stop but it will slow down and if you hit the brakes you should be able to stop in the trailer whether it's a 53' or even a 48'. Most of these regular trailers have an oak floor so you can scab cargo in except for the steel plate in the front over the king pin. Other trailers have an aluminum floor. Then there's also some that the floor is completely covered in rollers, not the type of trailer to pull this stunt with. They do make trailers with low loading heights, not dock height, for enclosed car hauling. These trailers are specifically meant to accomodate different vehicles, similar to this, but I don't think this is the type of trailer you meant for this experiment. |
Sure it can be done at a slow speed but at above the speed that you can stop in 60ft it would be essentialy impossible. even with a front wheel drive car you would still be going whatever speed in relation to the truck and no longer to the ground. and when you braked you would be braking the back wheels too and there for almost pulling yourself off the trailer.
I'd say you could do it. My vehicle for it? Some jeep. Lots of ground clearance, not too wide. But, if you screw up... well, that jeep will not be in as good shape as, say, a Corvette. Approach at about 7 mph faster and switch to fwd mode (I assume Jeeps can, I don't know) when the ramp is hit, and drop the rpms. The second the rear wheels are on, brake. It might work. (esp. with aftermarket brakes)
id go with a rwd. roll the front up thats easy enough. and then just go 1mph faster than the trailer and roll up. even if the car is going 101 and the trailer 100, the 100-0 mph deceleration would be very slow because its ONLY decelerating the rotational inertia. not the whole car's. so with a little rubber mark it should stop easily. its prolly harder to do in fwds like minis tho. stick a linelock in there and mightbe easier. or if its slower speeds go in reverse and parking brake. |
Should probobly just ask KITT
#12
EDIT: I'd imagine the ones broadcasted in TV shows used automatics though. Do you think the different transmissions would make a difference? Last edited by Eric Scheuing : 25-07-2006 at 23:13. |
#13
Its all driver skill, each has its pluses and minuses but a good driver will be able to utilize whichever transmission given.
| GM Announces Autonomously Driven Car | Tom Bottiglieri | Math and Science | 29 | 04-09-2005 22:20 |
| Gas R/C car | John Gutmann | Technical Discussion | 22 | 15-08-2005 14:35 |
| Make a queue of packets-Delphi | Zarkon | Programming | 1 | 22-03-2005 08:40 |
| Mars Rover on Car Talk! | mightywombat | Televised Robotics | 2 | 18-05-2004 14:41 |
