Re: Will the car make it in?
I'd say you could do it. My vehicle for it? Some jeep. Lots of ground clearance, not too wide. But, if you screw up... well, that jeep will not be in as good shape as, say, a Corvette. Approach at about 7 mph faster and switch to fwd mode (I assume Jeeps can, I don't know) when the ramp is hit, and drop the rpms. The second the rear wheels are on, brake. It might work. (esp. with aftermarket brakes)
id go with a rwd. roll the front up thats easy enough. and then just go 1mph faster than the trailer and roll up. even if the car is going 101 and the trailer 100, the 100-0 mph deceleration would be very slow because its ONLY decelerating the rotational inertia. not the whole car's. so with a little rubber mark it should stop easily. its prolly harder to do in fwds like minis tho. stick a linelock in there and mightbe easier. or if its slower speeds go in reverse and parking brake. |
Should probobly just ask KITT
#10
EDIT: I'd imagine the ones broadcasted in TV shows used automatics though. Do you think the different transmissions would make a difference? Last edited by Eric Scheuing : 25-07-2006 at 23:13. |
#11
Its all driver skill, each has its pluses and minuses but a good driver will be able to utilize whichever transmission given.
| GM Announces Autonomously Driven Car | Tom Bottiglieri | Math and Science | 29 | 04-09-2005 22:20 |
| Gas R/C car | John Gutmann | Technical Discussion | 22 | 15-08-2005 14:35 |
| Make a queue of packets-Delphi | Zarkon | Programming | 1 | 22-03-2005 08:40 |
| Mars Rover on Car Talk! | mightywombat | Televised Robotics | 2 | 18-05-2004 14:41 |
