Go to Post There are simply not enough words to say how much the contributions of Dave and Woodie have given to FIRST, and countless students across the world. - Libby K [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia
Unread 22-04-2006, 18:04
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Will the car make it in?
This is a question I've pondered for a while, and it became reinspired by the airplane-treadmill discussion.
I'm sure we've all seen the movie scene where the sports car is speeding down the freeway, there's a semi truck ahead that lowers a ramp, the car drives up the ramp into the trailer, the door closes and the cops come blowing past.
Is this possible?
I'll leave this open before posting my own thoughts - I wouldn't want to bias anything or anybody.
Hi!
Unread 22-04-2006, 18:35
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Will the car make it in?
Originally Posted by boiler
Is this possible?
Yes, a car can get IN to the truck, but I'm assuming you don't want the car to end up trough the wall and into the cab of the truck right? You want it to STAY in? lol
OK, here we go.
Well, some people know that I suck in physics (taken the class like 4 times and still haven't passed) so.. I'm just going to give a common sense reply.
Assuming you are on a highway and the tractor trailer truck is going 60mph:
If car is going double the speed of the truck, then it won't work because the car will not be able to stop in the truck in time (would have to do 60-0 in about 60ft.. (an average trailer is 53' long + the ramp)
If the car is going 60mph then it won't work as well, cause the car would just be pacing the truck behind it.
But, I think it would work if you are going ~10 mph over the truck's speed, and you will have enough time to go up the ramp and stop before you hit the end of the front of the trailer (behind cab) and it will work.
I think having a front wheel drive car, as opposed to a rear wheel drive car would impact these results differently as well.
If you have a front wheel drive car, those will catch the ramp first, and shoot you in the truck at a different rate, and with more time to slow down than a rear wheel drive car.
If you have front wheel drive, you can get the front wheels on the ramp.. and hit the front brakes, and you will be on the ramp and stopped. but rear wheels will still be rolling off the ramp (on the ground). so.. then you can just use that front wheel drive to go 10mph up the ramp and into the truck.
It would be a lot harder doing it with rear wheel drive, cause as soon as your wheels hit the ramp you are doing 60mph on a static surface (ramp into truck).
I think this would be a good mythbusters episode btw.
OK, so.. anyone want to throw in some "real" physics data to back me up, or strike my theory down?
Unread 22-04-2006, 18:44
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i've always assumed that you accelerate to a slightly faster speed than the truck, then put the car in neutral right before you entered the trailer, and coast in, using the breaks as needed.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 22-04-2006, 19:34
Andrew Blair's Avatar
FRC #0306 (CRT)
I'd say it's definently posible to do, but I wouldn't want to be the guy in the car, or the owner of the car. Reason?
Semi-trailer ramps are steep, and sports cars are low. With some damage to the front of the car and one very rough entry, you could probably make it in.
Other than that, I'd say Elgin's probably got it pretty well down. I hope this won't turn into another "Will the Airplane take off from the treadmill?" thread...
-Sir Francis Bacon
-Albert Einstein
Unread 22-04-2006, 21:15
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
yes it can be done have u seen the chevy comercials from about a year ago when they had the SSR do it backwards.
And in fear factor teams around the same time they had the driver blidfolded and their partner had to guide them through it. one team did it
and on a smaller scale(I.E. at about 15 mph) i have done the same thing w/ a garden tractor and a utility trailer.
KK4KQO
http://voltair.us
Unread 22-04-2006, 21:16
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
I agree with what you said, it can be done.
It would also be rough on the drive line of the car, although not as rough as exiting the truck at speed. A sports car isn't a necessity though, it can be done with almost any vehicle.
Also don't forget that as soon as the car hits the ramp it will lose some momentum due to the upward angle of the ramp, not enough to stop but it will slow down and if you hit the brakes you should be able to stop in the trailer whether it's a 53' or even a 48'.
Most of these regular trailers have an oak floor so you can scab cargo in except for the steel plate in the front over the king pin. Other trailers have an aluminum floor. Then there's also some that the floor is completely covered in rollers, not the type of trailer to pull this stunt with. They do make trailers with low loading heights, not dock height, for enclosed car hauling. These trailers are specifically meant to accomodate different vehicles, similar to this, but I don't think this is the type of trailer you meant for this experiment.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 22-04-2006, 21:50
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Sure it can be done at a slow speed but at above the speed that you can stop in 60ft it would be essentialy impossible. even with a front wheel drive car you would still be going whatever speed in relation to the truck and no longer to the ground. and when you braked you would be braking the back wheels too and there for almost pulling yourself off the trailer.
MechWarriors 573
Unread 22-04-2006, 22:21
in between teams
AKA: Luke Van Oort
I'd say you could do it. My vehicle for it? Some jeep. Lots of ground clearance, not too wide. But, if you screw up... well, that jeep will not be in as good shape as, say, a Corvette. Approach at about 7 mph faster and switch to fwd mode (I assume Jeeps can, I don't know) when the ramp is hit, and drop the rpms. The second the rear wheels are on, brake. It might work. (esp. with aftermarket brakes)
Team 1219: 2009 - Mentor
Unread 22-04-2006, 23:34
occra 23.
AKA: ryo
None #1481
eh... i disagree. first off a stock jeep wont switch to fwd. and noone i know would ever modify their jeep to do that.
id go with a rwd. roll the front up thats easy enough. and then just go 1mph faster than the trailer and roll up. even if the car is going 101 and the trailer 100, the 100-0 mph deceleration would be very slow because its ONLY decelerating the rotational inertia. not the whole car's. so with a little rubber mark it should stop easily. its prolly harder to do in fwds like minis tho.
stick a linelock in there and mightbe easier. or if its slower speeds go in reverse and parking brake.
Unread 22-04-2006, 23:54
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Should probobly just ask KITT
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 23-04-2006, 02:19
I was waiting for that reference... LOL
Unread 23-04-2006, 10:32
in between teams
AKA: Luke Van Oort
Okay, I didn't know that. I just know some 4WD vehicles can, and the jeep seems like a good fit in other manners. Now that I think about it more, how about a motorcycle? Be pretty easy in that I'd think.
Unread 23-04-2006, 10:39
occra 23.
AKA: ryo
None #1481
now that i think about it, jeeps are fine if you have a winch. neutral, and winch it in. apply brakes as needed
Unread 23-04-2006, 10:58
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, exactly. The rotational inertia of the two wheels (at a time) is small. The relative speed of the two vehicles is what is important here. Once you hit the ramp, you will have to accelerate to get up the ramp, and stopping once you're in and up will be fairly easy.
Cool! Why don't YOU live in my neighborhood?
Don
Unread 23-04-2006, 13:04
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
I believe that that is exactly right. The pictures of kitt doing it also prove that it is possible, as those are not models
GM Announces Autonomously Driven Car Tom Bottiglieri Math and Science 29 04-09-2005 22:20
Gas R/C car John Gutmann Technical Discussion 22 15-08-2005 14:35
Make a queue of packets-Delphi Zarkon Programming 1 22-03-2005 08:40
Mars Rover on Car Talk! mightywombat Televised Robotics 2 18-05-2004 14:41
