Go to Post I'll not deprive you of the practice in reading the manual; you'll need it if you want to be an effective part of an FRC team. - Alan Anderson [more]
Unread 23-04-2006, 03:19
Billfred's Avatar
Billfred Billfred is offline
2006: Did anyone use the Mabuchi motor?
Alright, the 2005 edition only netted one result, but this year's game required quite a few different mechanisms.
So, who used the little Mabuchi motor in the kit of parts on their 2006 robots?
Unread 23-04-2006, 10:23
in between teams
AKA: Luke Van Oort
Re: 2006: Did anyone use the Mabuchi motor?
No, when I was giving the engineers and studets information about all of the motors, I actually started describing the Mabuchi with "This motor sucks, a lot, almost nobody used it last year." But, anyway, the only function I can see using that weakling for is maybe a agitator or ball release of some sort.
Team 1219: 2009 - Mentor
Unread 23-04-2006, 11:24
DonRotolo's Avatar
Back to humble
FRC #0832
Nope
That's the little one with the gear on the end, right? We tried using it as part of our ball feed mechanism, but ended up using a window lifter motor instead. It was nice to have the option of using a small, light motor for something, but having the option and actually using it are two different things, I guess.
Don
Unread 23-04-2006, 11:31
Andrew Blair's Avatar
FRC #0306 (CRT)
Considering weight to wattage, it just isn't efficient compared to the Fisher Price.
-Sir Francis Bacon
-Albert Einstein
Unread 23-04-2006, 11:35
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: Nope
The only team that I saw using it (i think it was a Mabuchi) was 45 the Technokats when they installed their new shooter, they used it to move the balls into the shooter wheel. I found that there was very little it could do for us.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 23-04-2006, 12:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We were planning on using it to actuate one of the old seat motor screw mechanisms, to adjust the hood of our shooter, but due to weight, time, and complexity issues, we never put it on the robot.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-04-2006, 13:18
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
Re: Nope
I believe we are using the Mabuchi for that function also.
The irony of this discussion is that the Fisher Price motor is also made by Mabuchi and can use many of the same transmissions.
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
Unread 23-04-2006, 13:22
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
We used it to turn our turret. We use one stage of gear reduction to slow the motor down, other then that it have plenty of power for what we are using it for. It is similar to the FP, but with less power and speed.
Unread 24-04-2006, 07:55
Dkoning Dkoning is offline
Dkoning has a spectacular aura aboutDkoning has a spectacular aura aboutDkoning has a spectacular aura about
Team 74 did. We used the mabuchi motor with a bane bot gear box to run a winch to raise and lower our shooter.
Unread 24-04-2006, 08:19
We use it as a tachometer for maintaining the shooter wheel(s) speed.
Unread 24-04-2006, 09:09
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We put the Mabuchi on a 5:1 BaneBots transmission to direct-drive our front ball sweeper. The mechanism was just a 14" piece of 1/2" I.D. PVC pipe, cross-drilled in several places and thread thru with cable ties to form whiskers. It was supported by face mounting the gearbox on one end and a bolt on the other end, with bronze bearings pressed into the pipe on each end. The motor end was locked to the shaft with a set-screw. Total weight including the motor and gearbox was 1.4#.
The pipe was damaged in collisions a few times, but the motor/gearbox combinations never gave us a problem.
Richard Wallace
since 2003
Unread 24-04-2006, 10:32
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
This sounds white-paper worthy.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 24-04-2006, 10:36
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
we plugged it into the FP gearbox and used it to lift and lower our harvester mechanism. the motor is very weak, but the common can size makes it nice for use in a banebots or the FP!
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-04-2006, 11:56
Pat234's Avatar
Pat234 Pat234 is offline
None #0234 (www.cyberblue234.com)
Team Role: Human Player
Pat234 will become famous soon enoughPat234 will become famous soon enough
Team 234 put the pinion from the fisher price motor on the mabuchi and coupled it with the fisher price gearbox. This gives a slow and controlled output we use to pan our shooter
Life is a trip the best way to get started is shut your mouth and keep walking. -Anonymous
Unread 24-04-2006, 12:09
I actually have one, but I want better photographs of the tach mount and wiring, and those would be in Atlanta...
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
FIRST Technical Crash Course Alex Burman Technical Discussion 10 16-12-2005 23:04
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
Mabuchi motor gear specs? Salik Syed Motors 1 11-01-2005 20:25
