Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Unread 23-04-2006, 14:55
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: pic: Crab Drive
judging from the picture it looks like the middle of your wheel and the center of rotation of your module (the vertical rod, i'm assuming) are offset from each other. depending on the wheel traction and strength of your drive and rotation motors, this could cause it to behave oddly. also, if you were to get into a pushing match with this set-up, your modules could get pushed out of alignment as well. this is not really a major problem; all you need to do is shift the module's center of rotation so that its centered over the wheel.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Controls for a Crab Drive Ein Control System 22 26-01-2005 20:31
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
