Go to Post MORAL: Always wear safety glasses when you're putting on your safety glasses. ;) - Joel Glidden [more]
Unread 23-04-2006, 14:48
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
pic: Crab Drive
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 23-04-2006, 14:55
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: pic: Crab Drive
judging from the picture it looks like the middle of your wheel and the center of rotation of your module (the vertical rod, i'm assuming) are offset from each other. depending on the wheel traction and strength of your drive and rotation motors, this could cause it to behave oddly. also, if you were to get into a pushing match with this set-up, your modules could get pushed out of alignment as well. this is not really a major problem; all you need to do is shift the module's center of rotation so that its centered over the wheel.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 23-04-2006, 15:46
Joe_Widen's Avatar
Re: pic: Crab Drive
Yeh I realized that. Then I thought that would help when turning the wheels because the wheel would roll a little and we wouldnt try to be turning on wedgetop treading.(I tried ot make up a reason it might be good instead of changing it, and be a bit unique) Also, I plan on haveing a 5" Aluminum circular plate at the bottom of the plate to help spread weight evenly. I also plan on putting a lazy susan or something on it to mount the robot to. The focal point of this Module is that its very easy to make/put together. Minimal welding and machining, lots of standoffs and screws making it very easy to fix and maintaing.
Unread 23-04-2006, 15:49
in between teams
AKA: Luke Van Oort
Re: pic: Crab Drive
Looking at this makes me think that it would be easy to make a ball-bearing shifter and build that into a swerve module. Now, that'd be awesome. I agree with RogerR on the rod placement, and I'll add that you might want to consider moving the wheel down some, it looks like it brings the module too close to the ground. You have to remember that the wheel material will compress a bit with the robot's weight on it and wear down a bit.
Team 1219: 2009 - Mentor
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Controls for a Crab Drive Ein Control System 22 26-01-2005 20:31
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
