Go to Post the point is that FIRST is successful, in so many different ways - Pamela [more]
Unread 23-04-2006, 15:37
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
Re: Jammed Ball Bin-Storage Help!
If you saw our hopper at Davis, it jammed but required only minor shaking of the robot to unjam it. it holds about 15 balls, but yours would be mounted lower, allowing more capacity
Stop by our pit at nationals to take a look at our hopper.
Unread 23-04-2006, 15:41
run the trap!!!
Team Role: Human Player
Thanks for all the input!
It seems like the most widely held opinion is that gravity-fed bins will always have the potential to jam.
Realizing this, I think my best bet is to make some kind of agitator (probably like the one drawn by BurningQuestion).
Despite my preliminary misgivings I am beginning to see how using an agitator might actually be easier than redesigning the bin.
Based on people's ideas (and the bins of other robots) I created a CAD model of the new bin. It is similar to the bin most people thought was least likely to jam (bin #2), with offset angles (as recommended by Jonathin Norris).
Looking at the design I am already beginning to see new jamming issues. There is also the problem of how to transport the plastic to Atlanta...
Overall it looks more difficult to build than an agitator, which is probably what I'll wind up doing.
Does the new design look workable/less likely to jam?
-Philip J. Fry
Unread 23-04-2006, 16:27
razor95kds's Avatar
The design is very similar to 254's hopper. theirs still jammed and required shaking to unjam it
Unread 23-04-2006, 16:45
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
It will be awfully hard to keep them from jamming without an agitator of some sort. Maybe if you did somethng like this. Shallow sides.
(crudely done on MS Paint) Both sides should be the same distance from the smaller opening.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 23-04-2006, 16:52
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We found that the most jamming came from balls being stacked vertically, just like in the pictures you just posted. We made the bottom of our hopper large so that none of the ten starting balls were stacked on top of each other. If the balls are put in in the same pattern at the beginning of each match, then it will work every time (it did for us)
I highlighted the funneling parts of the hopper in our picture. The bottom of our hopper is at about a 30 degree angle and the two strips near the bottom just keep balls from getting hung up on the walls near the bottom. We also tried to put a shelf in right over the exit to prevent stacking, and it did it's job perfectly.
Unread 23-04-2006, 17:12
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Shallow sides BAD...
Yea we spent a lot of time on this during the season and found that we got the lowest amount of jams with a hopper 3 wide funneling into a single channel. Having one side slightly higher, like no more than 1" helped. But you need the relatively steep slope in there. The steeper the slope the greater gravity is acting on the balls, helping to get rid of jamming. But in any of these systems without an agitator there is the potential for jamming.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 25-04-2006, 10:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
another idea....a hopper that's only one ball wide, this is the side view. the ramps would keep the balls in line.
Ball speed testing after matches Ken Loyd Rules/Strategy 26 29-03-2006 22:36
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
What Storage Media Do You Prefer amateurrobotguy Chit-Chat 31 10-03-2005 19:39
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
