Go to Post Although I have much yet to go, in my short time in FIRST I have learned there is no such thing as a waste of time, especially when a) fundraising, b) mentoring students, or c) reading directions. - Amanda Morrison [more]
Unread 23-04-2006, 16:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
New Ryobi 3-speed drill transmissions!
In response to this thread, I was looking around on the Internet today for spare ransmissions for a 12v 2-speed Ryobi drill.
As I was searching, whenever I saw something that immediately caught my attention. I came across a new 18-volt hammer drill from Ryobi that has a three speed shifting transmission. Yes, you heard that right, Dewalt is not the only company that manufactures 3-speed drills. The outside of the drill looks remarkably similar to the Dewalts, and if this drill is anything like other Ryobi tools, it is probably half the price of a Dewalt.
Product information: http://www.ryobitools.com/index.php/catalog/tool/p220/
Product manual: http://oneworld1.inetu.net/manuals/r...20_541_eng.pdf
Speeds: 370 rpm, 750 rpm, 2,200 rpm
I think you may actually be able to use this transmission just like one of the NBD transmissions, with the exception that the servo-shifting will have to be rotated 90°. But otherwise, if you take the handle off, you will have a nice spot to secure one of the huge shaft collars; and right behind this spot you have four bolt holes that run parallel to the output shaft that could be used to bolt the CIM motor plate to the transmission.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-04-2006, 17:08
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: New Ryobi 3-speed drill transmissions!
Looks good except one thing. Its a hammer drill. From my knowledge and use of hammer drills they are different from regular drills, when they get up to their stall torque instead of just stopping they have a hammer action that bangs the drill forward to help commonly through concrete and/or cement.
Do you have the ratios as oppposed to just the speed with a ryobi motor attached?
MechWarriors 573
Unread 23-04-2006, 17:23
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: New Ryobi 3-speed drill transmissions!
Hi Art,
Found a link that will take you to a web site that has a part listing for the Ryobi P220 drill. It appears to me that Ryobi only offers the drill motor/transmission assembly as a repair part. That will likely be fairly expensive, and you can't use the motor. I guess you might want to get a price, and disassemble to see how it is built. Dewalt's are pretty cheap compared to most planetary gear transmissions I have seen. I do like the apparent gear ratios available with the Ryobi. Ryobi's 3 seem more useful then the Dewalt's 3.
Unread 23-04-2006, 17:34
Hodge1
Hi Art,
Found a Forum on Ryobi, and users are not happy with the the Ryobi. Uses bushings instead of ball bearings. It seems to be built similar to the Boesch trannys we used a few years ago. Found the price on the drill motor/tranny assembly as well. $92.66 is steep compared to Dewalt's needle/ball bearing output shaft. I would keep looking, but the Dewalt's will be hard to beat.
Link to forum: http://209.235.218.9/dc/dcboard.php?...g_id=806&page=
Unread 23-04-2006, 18:08
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There should be a switch to lock out the hammer mechanism. Additionally, if you're going to the trouble of disassembling it, it should be simple to remove the offending parts entirely.
I noticed this as well; we found that the DeWalt XRP's 3rd gear was hardly used, since 2nd is so close, and since the XRP's shifter has a long travel.
I was wondering about this—the DeWalt's bearings (needle and ball) are a nice (but expensive) touch.
Unread 23-04-2006, 19:48
artdutra04's Avatar
Hi Art,
Thanks for the link. That's interesting that there isn't any ball bearing in it. Last night my father and I were taking apart an older 12v Ryobi cordless drill to take a look at the transmission inside, and we found out the hard way that there is ball bearings in the 12v (non-hammer) model. Then again, the drill we took apart was almost ten years old, which may have explained the better quality.
I love the Dewalts, and I know that they are of a way better quality than the Ryobis. I just found this drill, and thought I would post it here because there may be some applications (non drive-train) where you could use a cheaper transmission. I was just looking around for a cheap source of a second transmission identical to the one we now have when I found this. Once we get a second one, I'd like to try using them on a Vex robot drivetrain. When that Vex robot hits 8.8 feet/sec, you'll see some serious stuff!
Art Dutra IV
世上无难事,只怕有心人.
DeWalt Transmissions - XRP Drill source !! Stu Bloom Technical Discussion 2 13-01-2006 22:34
Speed Reduction for Drill Motors Ian W. Programming 5 18-01-2003 23:57
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Difference in forward/reverse drill motor speed archiver 2001 25 24-06-2002 00:21
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
