Go to Post After all, if matches were determined by the numbers, we wouldn't need to have competitions. - jamierose [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-04-2006, 13:00
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Heat Sensor
I checked, but couldn't find a better place to ask this. Is there anyone who knows where I can buy a heat sensor, for a relatively small price?
VEX Robotics Blog
Unread 17-04-2006, 13:24
Re: Heat Sensor
Do you mean something like a thermocouple, a pyroelectric detector, or a thermistor? I think you need to give more information before you get a useful answer. What do you want the "heat sensor" to do? How much do you consider "relatively small"?
Unread 17-04-2006, 15:01
Umm Errr...
Re: Heat Sensor
If you mean a remote sensor then http://www.acroname.com/robotics/parts/c_Sensors.html
1139 Alumni
Unread 17-04-2006, 15:07
irishninja's Avatar
AKA: Nathan Bixler
Re: Heat Sensor
Originally Posted by Rickertsen2
Exactly. I just wanted something that could measure heat in an analog fashion. Something along the lines of those light sensors in the VEX kit, but instead of light heat. Thanks a ton.
VEX Robotics Blog
Unread 18-04-2006, 20:30
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Re: Heat Sensor
The KOP gyro has a thermometer (I haven't tried using it though)
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 18-04-2006, 21:04
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Heat Sensor
Hmmm... Not to hijack your thread, but can you use an IR sensor to detect heat? Wouldn't the amount of recieved infrared light be proportional to the temperature of the object? But it would be affected by distance...
-Sir Francis Bacon
-Albert Einstein
Unread 24-04-2006, 08:58
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
Re: Heat Sensor
The KOP gyro does double as a heat sensor. Its very wasy to use as well, just an analogue in. I tried it, its a good lil bugger.
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Sharp IR distance sensors Gdeaver Electrical 13 10-02-2007 20:36
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
jumper cabling from sensors to controller Gary Dillard Electrical 4 23-12-2005 07:42
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
