Re: Pic: Easy to make mecanums..
As of now the lab stops are on bolts. This was just for the picture ![]() We are in the process of ordering a bunch of .250 ID 1" length bushings to put in all the rollers. They will then run on a ground steel shaft that is pressed into the wheel housing, with E-rings on the edges to keep the rollers from sliding off. We know that the wheels are slightly fragile with the rollers outside the wheel like that, and the steel roller shafts would be prone to bending. But like most robots, we plan to have our wheels well protected from all sides. The wheels can take huge forces radially, because if pushed hard enough the rollers will compress and the wheel bottoms out against the aluminum housing. This takes about 150-200 lbs per wheel to do. A side note, efficiency is not reduced by weight on the wheel (other than more friction in the bushigns) because there is enough clearance on the sides of the rollers to allow for expansion due to weight compression. Also, these wheels get very good traction because the rollers are made of gum rubber. This means that all the rollers will have to be replaced every regional, but at 25 cents a piece from mcmaster, I dont think that will be a problem. Our goal from this is basically to have an agile mecanum robot with lots of traction and pushing power, something not common with omni-directional robots. Look forward to designs for ball shifting transmission for each wheel... |
For some reason I'm contradicting myself, I've designed a set of these before, but I think I might have done them wrong; what angle are the rollers supposed to be offset to the hubs?
Its not that 45* is most efficient. It is that 45* results in the max speed to the side is equally to the max speed forward. They are actually less efficient than say 30* because the rollers need to turn faster when moving in a direction other than forward. Of course 30* also means that the max side speed is lower than the max forward speed and the pushing power is greater.
A little birdy told me that free mecanums are always the easiest, but if you don't win them these are pretty darn cool!
Question:
Most mecanum wheels have the rollers at a 45* angle on 2 axes (I think you all know what I mean, at least, I hope it's clear: the rollers are at a 45* angle to the wheel and then angled upwards, correct?) Is this necessary, is it simply for increased traction, or could one theoretically design a mecanum wheel more in the style of an omni wheel, simply rotating the rollers to a 45* angle instead of a 90* angle? |
#8
The finished mecanum! (Sorry about the glare)
![]() A comparison with the spares. ![]() Much lighter now ![]() |
#12
Excellent job 1072 very nice machining process. I also love what you have done on being able to lighten the wheels. I like the fact that 1072 makes most of the stuff they design and has some great initiative about things like that. Finally, amazing pictures.
-Drew |
#13
Wow...we've been extremely busy with other things for the past few months, but we're finally getting close to wrapping this project up (the mechanical aspect, at least...)
![]() Looks just like the CAD, doesnt it? ![]() We're using a kitbot to test the wheels for now. (two of the wheels are still uncheeseholed, which is why they're hiding in shame under the other two =P) Last edited by rachal : 07-11-2006 at 21:36. |
| Linux and new microcontollers. | djcapelis | Programming | 48 | 29-01-2005 00:26 |
| How to pass your inspection at Nationals, the EASY way | Matt Reiland | Championship Event | 0 | 04-04-2003 18:39 |
| Please help make the Nationals in Houston AWESOME ... You be the Tournament Director | Natchez | General Forum | 42 | 13-12-2002 18:50 |
| 5 points I make..(and a little excess) | archiver | 1999 | 7 | 23-06-2002 22:18 |
| (CURIE) Let's make this Easy for all of us. [scouting] | 157#1Driver | Championship Event | 13 | 22-04-2002 08:56 |
