Go to Post I learned that I don't have a clone, there are only 24 hours in a day, and I can't do everything I want to do (even though I tried) and I learned that I have to say "no" once in a while. - KathieK [more]
Unread 06-04-2006, 15:56
Re: SONAR Sensor Software Driver
Originally Posted by gnormhurst
Just a further update on the sonar system. We were successful in using the sonar to control our distance to the corner goal (our doors won't open if we're too close, and the balls won't go in if we're too far away). We used sonar both in autonomous and as a driver control (driver initiates "autonomous" using a button. Control is returned when the balls have been dumped or the driver hits the "abort" button.) We even got a Xerox Creativity Award for the system.
But here's why I'm writing this note...
We had a strange problem. The sonar system would give steady values until we enabled autonomous, and then the values would start to drop: 150, 150, 150, [start auto] 150, 150, 130, 115, 90, 75, ... All this while the robot was on blocks and unable to move!
I figured it was some bizzare resource interrupt limitation timing thing. Until I discovered that it would do this just by me running the motors. It took a mechanical engineer to put his hand on the frame and say, "I bet it's picking up vibration from the motors!" We removed the sonar unit and held it -- the problem went away. We ended up mounting the unit on a block of foam (a block we made by cutting up one of those balls from the game).
Oddly, the autonomous code seemed to work anyway. It only did this for long distances -- at short distances ( < 30" ) we didn't see this problem.
So, everyone --- be careful how you mount the sonar unit -- it can pick up vibrations and give bad readings!
Thanks again for the driver code -- we never would have been able to complete this in time without it!
-Norm
What were you trying to read a distance off when this happened? Sometimes the sensor gets screwy readings when it is pointed at a curved object. Silly sound waves.
Unread 27-04-2006, 18:31
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
We were pointing it at a wall in the Drexel gym. Big, flat and perpendicular to the robot's axis. The test we did of removing the sonar unit from the robot and just holding it there, an inch from where it was mounted, seemed to be conclusive proof that it was indeed vibration pickup from the robot. Further, mounting it on foam stopped the problem.
SPEAKING OF MOUNTING IT ON FOAM: be careful how you mount it to the foam. Just putting a block of foam behind the unit and screwing it down through the foam doesn't work: the screws transmit the vibration from the frame directly to the sonar unit. You must mount the unit to the foam, then mount the foam to the robot's frame. This gives isolation.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 27-04-2006, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Gdeaver
Instead of a new thread I'll post here. There is a new sonar ranging sensor on the market. New sonar The interesting points as I see it are - Nice price, narrower cone of detection, and 3 ways to interface. RS232, analog voltage and the normal pulse timing. Too late for this year but may be a worthy addition to next years sensor selection.
Darn it, I went and started a new thread before I saw this post!
In my defense: Gdeaver's post didn't show up on a search.
Anyway: The code to measure the pulse is very cool, but that new sensor also gives an analog voltage at 10 mV/inch - just a simple analog input and you're done...
Don
Unread 14-07-2006, 19:23
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
This may just be on one of those days again but how do you hook up the vex sonar sensor to the EDU robot.
Unread 14-07-2006, 22:33
You need to adapt the male connections on the Vex ultrasonic sensor to the male connections on the EDU. Either a female-female cable or replace the Vex ultrasonic cable ends with female connectors. You can also use those Y-cables that come in the FRC KOP each year to do the job.
Other than that you hook it up to the same digital output and interrupt input as used on the Vex.
Unread 19-07-2006, 02:20
Chermaine Chermaine is offline
Chermaine is an unknown quantity at this point
I was compiling SONAR_0.3 using MPLAB C18 and it was not successful.
Followings are the errors detected from the codes in sonar.c.
At function initialize_sonar()
1) SONAR_OUTPUT_CONFIG = OUTPUT
-->symbol 'TRISJbits' has not been defined
-->struct or union object designator expected
-->lvalue required
2) SONAR_OUTPUT = 0
-->symbol 'LATJbits' has not been defined
-->lvalue required
At function ping_sonar ()
3) SONAR_OUTPUT = 1
-->lvalue required
4) SONAR_OUTPUT = 0
-->lvalue required
I thought maybe the problem lies with the definition in sonar.h for both SONAR_OUTPUT_CONFIG and SONAR_OUTPUT (see following 2 lines)
# define SONAR_OUTPUT rc_dig_out16
# define SONAR_OUTPUT_CONFIG digital_io_16
It seems to me that the define statements is referring to the hardware part or maybe the MPLAB C18 compiler is unable to read it?
Would anyone reading this can share which compiler they use and how to go about solving this problem?
pls help. Thank you.
Unread 29-09-2006, 23:18
I have managed to solve the previous post questions.
At present,
I have modify the software code for my project application. I am using a PIC18F452 microcontroller for the ping sensor. Everything works fine until programming the USART code. The hyper terminal characters does not change when the distance of the object changes.
Can you help me? I have a very close deadline to meet.
Follow is the code i added prior to Mike's codes:
#include <p18f452.h> // version 1.1
#include <usart.h>
#include "sonar.h"
/* Set configuration bits
* - set HS oscillator
* - disable watchdog timer
* - disable low voltage programming
#pragma romdata CONFIG
_CONFIG_DECL(_CONFIG1H_DEFAULT & _OSC_HS_1H,
_CONFIG2L_DEFAULT,
_CONFIG2H_DEFAULT & _WDT_OFF_2H,
_CONFIG3H_DEFAULT,
_CONFIG4L_DEFAULT & _LVP_OFF_4L,
_CONFIG5L_DEFAULT,
_CONFIG5H_DEFAULT,
_CONFIG6L_DEFAULT,
_CONFIG6H_DEFAULT,
_CONFIG7L_DEFAULT,
_CONFIG7H_DEFAULT);
#pragma romdata
int i;
int distance;
void main(void)
int i=0;
Initialize_Sonar();
Ping_Sonar();
Hardware_Interrupt_Sonar();
Timer_Interrupt_Sonar();
Get_Sonar_Distance();
OpenUSART (USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH, 129); // open USART with baud of 9600
while(i<10)
putrsUSART("A");
putrsUSART(distance);
putrsUSART("B");
i++;
Unread 30-09-2006, 00:01
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Im not sure if im right about this but try this...
I put the whole thing in an endless loop..
#include <usart.h>
#include "sonar.h"
_CONFIG2L_DEFAULT,
_CONFIG3H_DEFAULT,
_CONFIG5L_DEFAULT,
_CONFIG5H_DEFAULT,
_CONFIG6L_DEFAULT,
_CONFIG6H_DEFAULT,
_CONFIG7L_DEFAULT,
_CONFIG7H_DEFAULT);
#pragma romdata
int distance;
void main(void)
   Initialize_Sonar();
   while (1)   // Endless loop
      Ping_Sonar();
      distance = Get_Sonar_Distance();   // Get distance and update variable
      USART_RX_INT_ON &
      USART_ASYNCH_MODE &
      USART_EIGHT_BIT &
      USART_CONT_RX &
      putrsUSART("A");
      putrsUSART("B");
Try that and see if it works...
Good Luck
Unread 30-09-2006, 08:11
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I think you may have overlooked this section in the readme:
Software Use:
Call Ping_Sonar() to update the distance reading. Call Get_Sonar_Distance() to return the distance between the sonar sensor and an object in inches.
The functions: Hardware_Interrupt_Sonar() and Timer_Interrupt_Sonar() are only meant to be called internally in the sonar software. You only need to call two functions: Ping_Sonar() updates the distance between the sonar sensor and an object and Get_Sonar_Distance which will return the distance in inches.
I'm not familiar with your application but give this a shot. Note that I added comments about adding a time delay. It may take up to 50mS for the sonar to find an object.
#include <usart.h>
#include "sonar.h"
_CONFIG_DECL(_CONFIG1H_DEFAULT & _OSC_HS_1H,\
 			_CONFIG2L_DEFAULT,\
 			_CONFIG2H_DEFAULT & _WDT_OFF_2H,\
 			_CONFIG3H_DEFAULT,\
 			_CONFIG4L_DEFAULT & _LVP_OFF_4L,\
 			_CONFIG5L_DEFAULT,\
 			_CONFIG5H_DEFAULT,\
 			_CONFIG6L_DEFAULT,\
 			_CONFIG6H_DEFAULT,\
 			_CONFIG7L_DEFAULT,\
 			_CONFIG7H_DEFAULT);
#pragma romdata
int i;
int distance;
void main(void)
  int i=0;
  Initialize_Sonar();
 		   USART_RX_INT_ON &
 		   USART_ASYNCH_MODE &
 		   USART_EIGHT_BIT &
 		   USART_CONT_RX &
  Ping_Sonar();
  /* You might want to consider adding a time delay here */
  while(i<10)
	Ping_Sonar();
	putrsUSART("A");
	putrsUSART("B");
 	i++;
Unread 03-02-2007, 22:48
daveydaycart daveydaycart is offline
FRC #0294
daveydaycart is an unknown quantity at this point
I've been trying to get this working today on the FRC Robot Controller. I've never programmed interrupts before though, so I'm at a stand-still as to what to do. I think I have the initialization for the pin driven interrupt done correctly, but I'm at a complete loss for how to get the timer working. Any help would be appreciated.
Unread 04-02-2007, 08:04
Carpe diem
I'm assuming you're using MPlab and not EasyC to program your robot. Where did you get your version of the default code? Also does the particular version you are using have a name? For instance, "2007 Default Code from IFIrobotics.com" or "Camera code version 2.0 from kevin.org". A link so I can download the default code would be helpful as well.
Unread 04-02-2007, 17:08
FRC #0294
Yes, I'm using MPlab to program. I got my default code from kevin.org, it is his camera code version 2.1.
Thanks for your help!
Unread 05-02-2007, 10:50
Carpe diem
In the file user_routines_fast.c you have to change the function InterruptHandlerLow(). Add the following code to the IF statement.
    else if (PIR2bits.TMR3IF && PIE2bits.TMR3IE) // timer 3 interrupt?
        PIR2bits.TMR3IF = 0;
        Timer_Interrupt_Sonar(); // Call SONAR Timer Interrupt Handler
    else if (INTCON3bits.INT2IF && INTCON3bits.INT2IE) // external interrupt 1?
        INTCON3bits.INT2IF = 0;
        Hardware_Interrupt_Sonar(); // Call SONAR hardware interrupt handler
Unread 05-02-2007, 18:34
FRC #0294
oooh I think it may be that when I added your code to InterruptHandlerLow() I didn't reset the interrupt flag within the two "else if" statements. I'll add that tonight and see if it works. Thanks!
Unread 14-02-2007, 21:29
Hey guys,
Version 0.3 of this software DOES NOT work with Kevin Watson's PWM driver.
I'm guessing its a dependancy on Timer 3.
So, dont use it, or fix it.
--Tom
Toshiba Cardbus Problem? jpsaul7usa Chit-Chat 12 01-01-2006 02:37
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Middle School Drivers ram General Forum 40 26-02-2003 17:01
