Go to Post "I'd like the teeter-totter..." - Billfred [more]
View Poll Results: what kind of controller do you use?
Joystck(s) 112 93.33%
Steering Wheel(s) 10 8.33%
Video Game controller(s) (please explain below) 7 5.83%
Other (please explain below) 8 6.67%
Multiple Choice Poll. Voters: 120. You may not vote on this poll
Unread 01-05-2006, 10:46
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
How do you drive your robot?
I was curious how other teams drove their robot? My team uses two joysticks and four two way switches mounted in a box. We've discussed trying to use ps2 controllers or a steering wheel, but only ever used joystcks. I want how wnat kind of controller you use and how does your team have it programmed?
Unread 01-05-2006, 11:11
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: How do you drive your robot?
2-stick open loop.
Unread 01-05-2006, 12:18
Billfred's Avatar
Billfred Billfred is offline
Three robots have come out of 1293. Bob, Ockham, and Chomp have all been driven by two joysticks, one for drive and one for the mechanism, open-loop.
Unread 01-05-2006, 12:34
Vexkingof716's Avatar
Vexkingof716 Vexkingof716 is offline
WHOS'CTEKS Driver
AKA: Cowpots
FRC #0716 (Who'sCTEKS)
Vexkingof716 has a spectacular aura aboutVexkingof716 has a spectacular aura about
All 6 of our robots are contrtolled by two joysticks. it drives like a tank.
Unread 01-05-2006, 12:41
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
All of our robots ahve been driven by Joysticks to my knowledge, *Cough* Will change next year */cough* and we have had open and closed loops to drive. (Controlled by a switch)...
Pavan
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 01-05-2006, 12:50
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
When will FIRST go back to those wonderful black flightstick joysticks. Those are the old ones from the prevous years the only had to buttons, making it very simple, and easy to grasp. The thing about those joysticks was that the return springs were stronger than 2005 and 2006 KOP controllers. For 604 this was a problem because if it was ever bumped, or set on a non-level surface, then the joystick would make the robot move when you least expected it. The new joysticks are WAY to touchy.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 01-05-2006, 13:33
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
They've been out of production for years. There simply aren't enough new ones to give out, and the manufacturer has exhausted their stock.
You could contact CH Products to see if they still have any stock of the gameport versions of their higher-end joysticks (which have additional buttons, and a different upper grip). But those are probably out of production as well, so quantities will be limited.
Personally, I've always been a fan of one-stick systems. Their downside is that certain common maneouvres (especially turning through a smooth arc) require that you place the joystick in non-obvious positions.
Unread 01-05-2006, 13:40
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Video game controllers - Logitech Dual Stick with USB cable removed and replaced with joystick cable hardwired to pots and switches
Unread 01-05-2006, 13:55
ClayScales ClayScales is offline
#0231 (High Voltage)
ClayScales is an unknown quantity at this point
Team 231 has, for the last several years, used a single joystick. We definitely prefer the older, black joysticks. Depending on the robot, we sometimes use the joystick trigger and/or top button for functions, and compliment these with control panel switches, levers, buttons or custom interfaces (last year we fabricated a two joint control, simulating our arm, that worked intuitively and perfectly) for whatever other functions we need.
This year found us using the joystick only for steering. Our ball pickup was controlled by a 3-position toggle: balls in, off and balls out for scoring to the corner. Another 2-position toggle powered our spinning wheel ball shooter. We used the brake function of the speed controllers and momentary push buttons for brake steering (one each for left and right, great at high speed) that we mounted on either side of a momentary push button used for shooting (the trigger). Another 2-position toggle overrode the targeting sensor shoot function (which we unfortunately had to use... arena and ambient lighting usually defeated our targeting sensor).
Although the control panel was designed so that the driver could operate all functions, we found that having the co-driver operate the override, shooter (driver pushed the trigger) and balls in/off/out functions worked best.
Clay Scales
Unread 01-05-2006, 15:25
KRoth's Avatar
KRoth KRoth is offline
AKA: Kaylin
FRC #0011 (MORT- Mount Olive Robotics Team)
KRoth will become famous soon enough
Send a message via AIM to KRoth
We originally had joysticks until one of our drive team members by accidentally tripped over the control set up while we were queued and only 30 seconds from taking the robot out onto the field. Luckily, one of our other drive team members was quick on his feet and improvised. We drove that match (and the rest of our matches till we lost in the QFs) with pens.
TEAM 11: A FIRST Robotics Team since 1996
If you're not bleeding, you're not on drive train. MORT 2007.
Unread 01-05-2006, 15:40
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Our drive is tank drive just as in previous years, and is driven by two Flightstick's. We made sure to keep all of the old ones that we had left over after they switched the kit ones, so we're stocked for future years.
Also, for this year we bought a project box and put in four switches, two pots, a rocker switch, and an easy button. It's posted on CD-Media. Last year we just used two joysticks for our arm, as we have usually done in previous years.
Team 177 - Bobcat Robotics
Unread 01-05-2006, 16:29
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
Very very carefully... lol
The drivers use joysticks, I want to say 1 each. Our joysticks however, are personalized in typical 1504 fashion... (see below)
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 01-05-2006, 16:54
spears312's Avatar
spears312 spears312 is offline
El Capitan
AKA: Ryan
FRC #0312 (Heatwave)
spears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nice
Send a message via AIM to spears312
We used the same ole' black flight sticks we have used for last several years. We almost ended up using a USB Xbox360 controller, but we never quite got around to finishing it, and our drivers already had more practice on the flight sticks.
HEATWAVE 312
2004 FL Regional Chairman's Award Winners
2005 UCF & Palmetto Team Spirit Award Winners
2005 Championship Curie Division Semi - Finnalists (thx to 118 and 229)
FIRST
Under Construction
Unread 01-05-2006, 16:59
Umm Errr...
we used the KOP joysticks this year, but our drivetrain operator got annoyed by their lack of centering springs relative to their bulky size. He ripped most of the stick off, leaving only little black nubs.
1139 Alumni
Unread 01-05-2006, 17:00
deficite's Avatar
deficite deficite is offline
AKA: Josh Taylor
FRC #0547 (F.E.A.R.)
deficite is an unknown quantity at this point
Send a message via AIM to deficite Send a message via Yahoo to deficite
Up until this year we'd used the old black kit sticks. This year we took the handle off the kit sticks from this year and replaced it with a turned piece of wood on both of them. Most of our drivers use tank steering, although a few have preferred single stick in the past.
The operator just uses some basic RadioShack buttons and switches we wire up to some plywood.
Behold the almighty signature.
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
If you could change one rule - eliminate ship requirement discussion Andy Baker General Forum 53 28-10-2005 22:23
Public apology from myself (Team 830) Don Wright Rules/Strategy 13 14-03-2004 22:02
Robot with segway drive platform Andrew Rudolph Dean Kamen's Inventions 1 14-11-2003 23:54
Wanna drive RAGE's robot? archiver 2000 1 23-06-2002 23:39
