Go to Post Is it January yet?? - Kevin Kolodziej [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
  #91   Spotlight this post!
Unread 13-04-2006, 17:10
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Online Aim High Game
wow i just got 241.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
  #92   Spotlight this post!
Unread 13-04-2006, 17:11
Billfred's Avatar
Billfred Billfred is offline
Originally Posted by burkey_turkey
and billfred, all i have to say is f with a lowbot
PWNAGE
which is why i prefer:
f2l4f9f9f6r3s
cheap and unramable. with autonomous isnt the highbot too much of an advantage? 40 points guaranteed, the lowbot can get 10, midbot possibly like 15-20. but with 40 in auto, even if it is taken out of the game by a pusher for the rest of the game it wins. hmmm, sounds familiar....
-turkey
It's only pwnage if you have an opponent.
One bug I noted: I just gave the lowbot the command of d. It alternates quickly between shooting and sucking, then goes to shoot and stays that way once you reach human control.
  #93   Spotlight this post!
Unread 13-04-2006, 17:14
Tim Delles's Avatar
Since 2001.
FRC #0078
make that 267
  #94   Spotlight this post!
Unread 13-04-2006, 19:14
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
that because, and i believe this is in the directions, d works just like the toggle dump/suck key q or u. when you end the autonomous without a number, it will execute that command once per frame till the end of autonomous. so 12 times a second you are toggling between dump and suck. this can be fixed by adding a 1 after the d. so if you end your code with d1, it will toggle once to go to shoot, then wait till the end of autonomous. or you can get more complex and type somthing alnong the lines of d1p9p9p9p9d1 and after dumping everything (keeping in mind the lowbot dumps twice as fast as the midbot)* you will begin sucking again so you are ready to go once autonomous is over
hope that helps billfred, and i would like to note that i recognized your picture, and i was at the palmetto regional a few weeks ago as well, in fact i believe i paired with you and we won that match! you were mentoring and i was secondary driver for 422, the lowbot that can push real good. nice to talk to you again!
-turkey
*note from above, i looked it up and the midbot dumps 3 balls a second, and the the lowbot dumps 6. 12 frames in a second so a full load for the lowbot would take 10/6 of a second, or 20/12 meaning p9p9p2. but also, it takes a few seconds for the ball to get out of sucking range, so give it a good p9p9p9 for the lowbot, and p9p9p9p9p9 for the midbot and i think you should be good.
  #95   Spotlight this post!
Unread 13-04-2006, 23:50
tfisher04 tfisher04 is offline
AKA: Tom Fisher
FRC #0422 (Mech Techs)
tfisher04 has a spectacular aura abouttfisher04 has a spectacular aura about
Okay guys. I just talked with Andrew, and he's ready to finalize this project. The final version is at http://www.team422.com/aimhighonlinegame.htm with all the updated shareware below it. Finally, I'd like to thank Andrew for making this game. Moreover, any of you who have suggestions get them in by tomorrow at noon, cause Andrew has said he's finalizing the game then. Good luck playing, and good night!
  #96   Spotlight this post!
Unread 13-04-2006, 23:57
AKA: Andrew
I would like to say goodbye everyone. my spring break is about up, and im put of time to goof off and program. I have done more with this game than i originally imagined i could ever do. it still isnt perfect, i know that, but i am proud of it. but because i am leaving tomorrow, i will need any bug reports/suggestions before 3ish friday. this includes final pleas for the score on the mat, and anything you find wrong with the program.
If you visit the team 422 site, www.team422.com/aimhighonlinegame.html you will find that we have compiled for your pleasure, downloadable versions of the game. there is one for macs, and one for windows. there is also one folder that contains everything you need, as well as the instructions, to put the game online yourself, on your teams site.
Enjoy the game, and tell your friends. I know once i am back from spring break, my team and i are going to have a tournament. Im gonna win ;-)
i hope everyone enjoys plying the game,
-andrew "burkey turkey" burks
  #97   Spotlight this post!
Unread 15-04-2006, 01:23
YonZ's Avatar
YonZ YonZ is offline
FRC #0694 (Stuypulse)
YonZ has a spectacular aura aboutYonZ has a spectacular aura about
244 im totally addicted
edit:266! w00t
Delles, i'm coming after your score!
Team 694
  • 2006- NYC Regional Website Award / NYC Regional Creativity Award / NYC Regional Finalists
  • 2005- NYC Regional Chairman's Award / NYC Regional Control Award / NYC Regional Semifinalists / Championship Galileo Division Semifinalists
  • 2004- NYC Regional Entrepreneurship Award / NYC Regional Quarterfinalists
  #98   Spotlight this post!
Unread 15-04-2006, 03:12
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
loving the final edition no complaints from me =D *maybe cause i got a new stragety =P*
love the auto!!!!
high score = 312 =D
*321... thats only 40 pts auto... i like the 10 pt bonus for some reason better than 60pts =P
325... i somehow scored 70pts in auto while shooting on 2 diffrent sides... =P the last 3 i guess counted at 120 /shrug... good stuff loving it AH!
*btw maybe like a best 2/3 elim tourney at nats???
347 =X... 350 definatley doable... anyone wanna try 400??? *thats 70 in auto now...
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
  #99   Spotlight this post!
Unread 15-04-2006, 16:55
Billfred's Avatar
I just got a 270 with the blue robot only doing a dump.
  #100   Spotlight this post!
Unread 15-04-2006, 20:16
AKA: Andrew
hello all, back in richmond, trying to focus on my put off french project. but i do have to say somthing:
fist off, a nice autonomous is one bot with:
f9f9l4s1p3s1p3s1p3s1p3s1p3s1p3s1p3s1p3s1p3s1p3r4b9 b9
the other with:
p9p9p9p9p9p9f9f9r4s
hehehehe. i like that one
and also, im gonna try to make a tournament version of the game, whre you start byu lining up 2,4,8,or 16 players who are automoatically put in brackets, and its played off like a regional except with an extra tier. dont count on that within the next week or so though, unless it prooves easier than i though
-turkey
PS: i have made an official challenge to everyone: on a different thread i posted that i would give a dozen krispy kremers to the person can turn my game into an online multiplayer one. as in, im in virginia playing someone in wisconsin. PM me or Email me for the source code (.fla file).
  #101   Spotlight this post!
Unread 15-04-2006, 20:58
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Cool Re: Online Aim High Game
the other with:
p9p9p9p9p9p9f9f9r4s
-turkey
That Sounds GREAT!
Hope that it ends up to be easier than you think.
Tomasz Bania
WOW, THIS HAS GONE ON FOR 100 POSTS NOW!
APERRANTLY WE LOVE FIRST GAMES!
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
  #102   Spotlight this post!
Unread 16-04-2006, 11:28
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Sorry guys, 212, with no fiddleing with the other robot (except atonomus)
ha!!! beat that.
ne1 willing to play agenst me at nats.
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
  #103   Spotlight this post!
Unread 17-04-2006, 23:22
ha!!! beat that.
well using just 1 bot and shotting on both goals i got a 333... shooting on just 1 goal i still got 259 just using one goal...
challenege meet and beat =D i would LOVE to play against you at nationals =D
  #104   Spotlight this post!
Unread 01-05-2006, 17:59
SizzelChest330's Avatar
SizzelChest330 SizzelChest330 is offline
AKA: Elijah
FRC #0330 (Beachbot)
SizzelChest330 is just really niceSizzelChest330 is just really niceSizzelChest330 is just really niceSizzelChest330 is just really nice
Send a message via AIM to SizzelChest330
For some reason I cant get the Highbot to do anything else in auto after it starts shooting
I wanna make one to run out shoot and then drive backwards and try to ram/ get ready to snake the other teams balls
can anyone help me out
heres what ive been trying
F3l1f9l2f9sb9r3b9
Go Beachbot!
  #105   Spotlight this post!
Unread 12-06-2006, 01:32
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
I just found this game yesterday and it is very cool and addictive.
Try this for auto:
Robot 1:
f9l4f9r4f9f4l4s9s9s9
Robot 2:
f9f9f3r4s9s9s9b9b9b9b9b9b9
My highest score so far is 278.
Great job by the person who made the game.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
2006 AIM HIGH strategy board now available! Dillon Compton Rules/Strategy 4 27-03-2006 15:42
FIRST is all mixed up.... Swan217 General Forum 11 23-03-2006 18:28
Aim High Dodgeball! Cyberguy34000 General Forum 26 18-01-2006 22:26
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
