Go to Post Attitudes in one part of life tend to carry over to others. - Wetzel [more]
Unread 01-05-2006, 22:37
Re: safety glasses??why??
Originally Posted by Don Rotolo
Invest $10 in a hallf-decent pair of safety glasses, and (believe it or not) after a short while you will literally forget they are on.... Good Glasses are just that.
Go to your local hardware store. Get a decent pair. Keep them from getting dirty by washing them (soap and warm water, then dry with a towel). Get a case to protect them when they aren't on your eyes. You should be able to wear them comfortably all day.
Unread 02-05-2006, 00:14
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Safety glasses are good anti-robot protection. I've had a corner of the robot from this year smack point first into my safety glasses, saved alot of hurt to my eye and probably the cost of buying new normal glasses as well, since they were under the safety ones.
Unread 02-05-2006, 23:09
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I personally think that safety glasses are a bit overdone. I totally agree with wearing safety glasses when cutting/drilling/grinding, but it just bothers me that I have to wear them when I do such dangerous tasks as putting stickers on the robot or sorting through my pocket change. This is mainly because I have prescription glasses and those huge goggles annoy the heck out of me.
I've worked on things for long enough to realize what is the safe way to do something and what is dangerous. I work on bikes and cars and other mechanical things at home without wearing safety glasses because I know how to work on things carefully so that they don't explode and fly across the room.
I do take the necessary precautions when working with powertools just like everybody should, but I think the danger of a bolt is greatly overexagerated.
Unread 03-05-2006, 00:41
OK, first off, you wear prescription glasses normally. IF they are polycarbonate, you only need side shields. That shouldn't be too hard, should it? I know of at least one person who has prescription safety glasses.
Second, just because all you are doing is, say, looking at the robot, that doesn't mean that someone else in your pit, or the neighboring pit, or the pit across the aisle is not doing something that could throw bits of material into your pit, and quite possibly into your eyes.For argument's sake, let's assume they are drilling plastic, say PVC. Now, PVC has a tendency to form a plastic mass on the drill bit, made up of "strings" of PVC, and these occaisionally fly off. (Metal does the same under certain conditions, and tends to fly off even farther.) One of those "strings" leaves a drill bit in the pit next door, and flies into your eyes at high speed before you can stop it. You are not wearing safety glasses, and it has enough momentum/energy/force to shatter your normal glasses. Now you have bits of glass in your eyes, as well as plastic. You could lose your sight.
Admittedly, this is a bit far fetched. I use it to make a point--and it could potentially happen with metal.
So, even if you don't understand the reason behind the rule, follow it. Would you rather put up with discomfort for three days, or suffer discomfort for the rest of your life?
Unread 18-09-2006, 12:35
s_forbes's Avatar
I know exactly where you guys are coming from, I'm usually way safer than I need to be. But I still stand by my original post, and I will continue to tinker on my own time without wearing safety glasses unless I see fit.
I thought it also might be worth mentioning that I have always worn my goggles when in the pits at a competition, and I wore them when working on the robot at our teams shop. Just because I don't completely agree with the rules doesn't mean I don't follow them.
Actually, I would much rather wear real goggles than those things. In the cases when I'm working on something where there is a significant chance of getting something in my eye (grinding, using the drill press, etc.) I want to have my eyes safe. Metal shards have no problem flying in over your glasses.
Sorry if I came off as some rebelious punk earlier, I didn't mean it.
Unread 18-09-2006, 17:12
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Safety glasses are a must not only in the pit, but anytime you are near a robot.
I do have one question though....why do you not like safety glasses that much? If you are so against them in the pits...I can only assume that you do not wear them during the build season.
I can understand where you may see a cheap pair as uncomfortable and causing messed up vision. However, If you have been involved in FIRST for any time then you would definately have a set of you own safety glasses that you could forget you were wearing.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 18-09-2006, 22:02
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Please do not assume such things...It makes an *bleep* out of you and me . Eye safety was our number one priority when we were working in the shop. I am very strict about safety, I'm sure that s_forbes will agree with this statement.
Unread 18-09-2006, 22:40
s_forbes's Avatar
I would completely agree with that statement!
Unread 18-09-2006, 19:52
capof541's Avatar
capof541 capof541 is offline
college student
AKA: Darvell
FRC #1270 (Red Dragons)
capof541 has a little shameless behaviour in the past
Send a message via AIM to capof541 Send a message via Yahoo to capof541
safety glasses on my team thats the first thing we stress being we started out at a trade school it was what we learned walking in the door so it was beat in our heads and the NASA engineers never let us for get that. but safety glasses have save me in other ways like grinding disks flying at me, but my favorite was when i put my glasses on my head cause i couldn't see and was under our tongue for our flipping arm in 2005 and the engineer manually pressed the button on the solenoid and 25 pounds of pressure came flying down on my head it luckily hit my safety glasses
guess what i have a new team dont let da name fool ya im part of 1270 now.
2005 ucf semi finalist 1251 & 845
winners of the 2006 Palmetto Regional engineering inspration award
2007 Florida regional champions thank you team 1251 86 see you at the nationals
Favorite quote's............. Where's a SHARPIE
Thats Those nasa engineers,
Measure twice cut once
Unread 09-10-2006, 16:14
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
i was the same way i didnt like saftey goggles.. them i dropped a can of aircraft remover and it sprayed my face .. now aircraft remover takes paint off of metal .. it was on my face and in my eyes.. now i awalys wear satey goggles.. one time i was wearign them and a drill bit broke and hit the goggles..just wear them.. $@#$@#$@#$@# happens
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 18-09-2006, 11:51
I've worked on things for long enough to realize what is the safe way to do something and what is dangerous. I work on bikes and cars and other mechanical things at home without wearing safety glasses because I know how to work on things carefully so that they don't explode and fly across the room...
You have worked on things for several years, and have accumulated several man-years of experience on what is potentially dangerous.
The industrial standards imposed for the use of safety glasses and other protection equipment is based on millions of people working in industrial environments for over a hundred years. By contrast your personal experience is 0.0000000000001% of the knowledge accumulated by the people who impose these rules.
I also sense a bit of protective ego in your post, the part of us that says "I know what Im doing, and Im carefull when I need to be carefull". This is not a bad thing, self confidence is necessary or we would never venture into a shop and use dangerous tools. But being carefull, being intelligent, and depending on your own experience is the same path that many other good people also followed, right up to the instant when they lost an eye or a hand.
Its the stuff you dont know about, the things you dont expect to shatter, the thing you never knew had a coiled spring inside that blows open in your face and gets you. Thats why many shops have signs at all the entrances: Safey glasses required beyond this point, because with all the variables that are out of your control, if you are present in that area, you are in harms way.
**FIRST EMAIL**/2006 FIRST Safety Awareness and Recognition Program Beth Sweet FIRST E-Mail Blast Archive 0 24-02-2006 15:34
Driver & Human Safety Kims Robot General Forum 15 27-04-2005 21:45
Competition Safety Eugenia Gabrielov General Forum 6 10-01-2005 19:47
Tackle that person with no safety glasses Stephen Sexton General Forum 50 01-04-2004 13:51
in search of Prescription safety glasses archiver 2001 3 24-06-2002 04:11
