Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
Unread 01-05-2006, 19:38
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Re: Sundial - Feedback Requested, Please
We were connected for most of Saturday, and I absolutely LOVED it. Having the rankings and match list was VERY useful when you're trying to see how the rankings could potentially fall out over the next few matches (which I do waaaay too much, but this made it easier). Plus, a few times we were saved from being very early to a match when the field was running behind. I'd love to see this at every regional next year, it was great.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 01-05-2006, 19:53
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Originally Posted by Rickertsen2
Were yall entering the data manually, or was it coming from the FIRST computers?
The Sundial server computer was set up on the scoring table behind Einstein field. We had two network cables plugged into the NASA switch there: one connected to the VLAN on which the four divisional scoring computers were located, and one connected to the WiFi VLAN. All the data was being transferred electronically from the FIRST scoring computers, and no human interaction was required.
The wireless networking was all provided by NASA. There was a single access point in the dome (intended mainly for diagnostic purposes) and I believe three in the pits, but as Jeff said the numerous ad-hoc networks were causing a lot of interference. Also, one of the access points lost its connection to the rest of the network on Friday morning, and wasn't repaired until much later that day. I apologize for this, and I will be doing my best over the next year to make the necessary arrangements so that this doesn't happen again.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 01-05-2006, 21:13
Mahalis Mahalis is offline
AKA: Noah Witherspoon
FRC #1139 (Chamblee Geargrinders)
Team Role: Animator
Mahalis is an unknown quantity at this point
Send a message via AIM to Mahalis
Our team found it useful on the few occasions we could connect to it. The signal was fluctuating like crazy in the Curie pits and when I tried to connect I alternately got "The 'first' wireless network is using an Access Control List to restrict connections" and "There was an error joining the wireless network 'first';" hitting "Try Again" twenty or thirty times usually got me in, but on Saturday I couldn't connect at all. Oddly enough, the signal seemed to work better in the Dome than in the pits - I only had to "Try Again" five or six times.
All in all, a really useful service that could benefit from some relay stations or a better antenna.
Unread 01-05-2006, 21:20
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
SUNDIAL IS AWESOME!
It was pretty much essential at Nationals. I really hope it is at every single FIRST event next season.
Many thanks to the creators of sundial!
-Q
btw: has a great name too
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 01-05-2006, 21:49
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Sundial was great at Nationals, when we could connect. I found that I had full signal, but I would have to try 5 to 10 times to get an IP address.
Zan Hecht
Unread 01-05-2006, 22:39
Tsom467 Tsom467 is offline
FRC #0467 (Shrewsbury Colonials)
Tsom467 will become famous soon enoughTsom467 will become famous soon enough
We used it in Boston and thought it was fantastic! We had a laptop set up in our pits that displayed the Sundial data, and one in the stands we were using for match data entry. The laptop in the pits also had access to our (custom) team data information site (complete with pictures, team info and match details.)
I'm sure we'll be looking forward to seeing it again next year!
Unread 01-05-2006, 22:55
Jessica!'s Avatar
Jessica! Jessica! is offline
I bet I can cheer louder than you..
AKA: Jessica Zavadil
FRC #0217 (ThunderChickens)
Jessica! is a name known to allJessica! is a name known to allJessica! is a name known to allJessica! is a name known to allJessica! is a name known to allJessica! is a name known to all
Send a message via AIM to Jessica!
Oh my goodness Sundial was so helpful!!!! Our team always pushes it to the limit when it comes to making our matches on time, so it was very helpful in gauging how much time we had etc. I hope this can be at every regional next year!!
Jessica
217 ThunderChickens
2006 World Champions!!
2006 Detroit Champions
2006 Detroit Woodie Flowers Finalist Ron Arscheene
2006 Detroit Chairman's Award Winner
2006 GTR Xerox Creativity Award
2006 GTR Sportsmanship Award
Wow talk about an amazing season!
Unread 02-05-2006, 02:26
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Sounds like it would have been very handy to have sundial running. I tried connecting to literally everything in the pits and seemed nothing connected anywhere. I could probably get close to 10 access points and 10-20 ad-hoc. I did connect to the sundial per the instructions but lost connection on Friday. Then I lost my wireless card (or was stolen) so that made it imposable to connect.
Thanks for the specs. Is this a program which you would be possibly allowing another team to run at other regionals which your team doesn't go to?
Does anyone perchance have screen shots so that I could at least see what this thing was all about?
-Mike Aalderink
Team 1654
Unread 02-05-2006, 04:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Our scouting person was wanting to use it, but her (new) laptop didn't seem too interested in connecting, and my laptop did eventually connect to it once I discovered the magical necessity of typing in www.sundial.first, but then it didn't work because you need some kind of flash thingy plugin that I don't allow on my computers. I only spent part of one morning trying to make it work.
But it is a neat thing anyways, I know Karen on our mentor team 842 made good use of it.
Unread 02-05-2006, 07:31
vadyr's Avatar
vadyr vadyr is offline
103 Alumni/Mentor - FIRST Volunteer
AKA: Bobby
no team (Cybersonics (Mentor))
vadyr is a jewel in the roughvadyr is a jewel in the roughvadyr is a jewel in the rough
Send a message via AIM to vadyr
I just wanted to say that i really liked the sundial service. We used it to stay on time, get our schedule, and check the results of our matches when we werent sure how we scored. Thanks a lot for putting sundial up!
www.cybersonics.org
Unread 02-05-2006, 12:01
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We really liked it when we could connect. The only issue was the continual up and down of the connections, but as has been said all the ad-hoc networks created a lot of interference which is most likely the reason for the sporadic connectivity.
I'd love to see this become a regular part of all FIRST events, it was extremely helpful since Curie seemed to be running between 5-10 minutes ahead of schedule it helped us a lot.
Thanks!
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 02-05-2006, 17:18
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I tried once. (It wasn't a high priority.) I think it must have been from our pit (Archimedes.) If memory serves me (which I steadfastly refuse to vouch ) it never acquired an IP address after about a minute.
When I used at the So Cal Regional, I found it of limited usefulness since the match results and standings were not available. It also caused some slight annoyance, since when I would scroll down the match list, it would periodically scroll back to the top whenever the list was refreshed.
Unread 02-05-2006, 17:49
Sagar Vyas's Avatar
Sagar Vyas Sagar Vyas is offline
Sagar Vyas
Sagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of lightSagar Vyas is a glorious beacon of light
Send a message via AIM to Sagar Vyas
Sundial was amazing, kept our team in the pit up-to-date, 1503 was using it at GTR on one of our dualview monitors. One of the only problems we ran into was the timing was a bit off, other than that, Great software!
Video on WLAN is also a great idea, 1503 created their own personal video wireless network and broadcasted it for the newton division. It worked out amazingly, isn't there a way Sundian can be integrated with a live video feed?
Team 1503, Spartonics - Alumni
Unread 02-05-2006, 18:13
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
Sundial was in my opinion, the most useful thing in our pit!
If you are interested in adding features to it, adding a tracker to keep track of our current rank, etc would be pretty cool...
Other than that, it's REALLY great.
Keep up the great work, Pat
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 02-05-2006, 21:47
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
We used it in Boston and it was amazing, extremely useful for a small team like us that don't have enough people to run around checking for matches.
We tried using it from our pits in Archimedes and, even though we could connect to the network, the site would never open. Quite a shame, especially considering we had an even smaller group in a much bigger venue.
Anyway, the service is great and I'd like to thank your team for putting it up!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Disappointed in Chairman's Award Feedback for 2006 galewind Chairman's Award 10 20-03-2006 22:31
I cant find Sundial... the new match sheat kjhobin General Forum 2 03-02-2006 07:32
Force Feedback Andrew Blair Control System 67 12-12-2005 18:40
Queuing Feedback David Gaylord Championship Event 3 20-04-2004 08:58
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
