Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 02-05-2006, 20:19
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Problem solved but now another question
I'm tyring to compile the default code for the Vex microcontroller. Unfortunately, MPLab can't find some of the header files. The odd thing is that I included the header files into the project and they are in the same directory as the default code.
**Never mind. Some of the files are defined locally while some of the others aren't. That's why the error message is appearing.**
Is there any significance as to the why some files are defined locally and some are not? Can I just change that?
Unread 03-05-2006, 08:54
Re: Problem solved but now another question
You can just change that.
The compile process allows you to do this essentially to allow you to override the standard includes and substitute your own. It does lend itself to confusion if you don't realixze how it all links together.
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
