Go to Post General rule of thumb: "If it moves and it shouldn't, use duct tape. If it should move and it doesn't, use WD-40.":) - ben_0614 [more]
Unread 04-05-2006, 07:54
Re: Bending 2" diameter pipe/tubing
Sandrag,
Muffler shops bend pipe but it changes the diameter to prevent cracking the side wall. Electricians bend pipe all the time. Any larger contractor should be able to make it happen in just a few minutes. I would ask around at your school, they liklely have a contractor they normally do business with who would do the job.
The bender you linked to is generally not designed to perform 180 degree bends. Most often these are used for 90 and 45.
Unread 04-05-2006, 08:54
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Conduit and pipe benders (like the one you linked) would do the job, but you'll be limited to their bend radii, which are pretty much standard. These mostly use a fixed bending shoe, proportional to the conduit diameter - I think code requires at least 6 X conduit dia.. For a "custom" radius, you'd need a different kind of machine. You might find a custom motorcycle shop which could do a custom bend for you.
In any case, at $75 the Harbor Freight machine may not be a bad route if it will do the job. You might pay that much in labor to have tubes bent for you.
Pete Kieselbach
Unread 04-05-2006, 11:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Conduit will work. It will be welded together, but we can grind off the galvanizing first and/or weld outdoors. It is possible that instead of a continuous 180 degree bend, that I can join two 90 degreee sections.
Today I'm going to go take a look at 90 degree EMT conduit sweep elbows, that harbor freight bender, and some exhaust shops.
Unread 05-05-2006, 03:11
Took a look at the HF bender. It's die is for 90 degrees. Looks like a decent unit, but repeatability may be a problem. Took a look at 1 1/2" EMT conduit sweep elbows. Liked em so much I bought a couple (only $5 each). The radius is pretty much perfect, and conduit will be nice because it won't rust and it doesn't cost too much. So, I think that's what I'm going to do. Cut and weld together two 90 degree 1 1/2 inch EMT sweep elbows. Seems like the easiest way out.
BTW, 1 1/2 EMT conduit is closer to 1 3/4 OD if anyone was wondering.
Unread 11-05-2006, 21:27
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You can also buy pre-bent tubing: http://www.woolfaircraft.com/elbow.htm from aircraft & speed/racing shops
[OCCRA]: diameter of the pipes iheartpi OCCRA Q&A 1 28-09-2005 20:26
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
