Go to Post What are you people going to rumor mill about if we ever actually get a water game? - Kevin Sevcik [more]
  #31   Spotlight this post!
Unread 04-05-2006, 20:58
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Brakes
Originally Posted by fsayre
Sounds like a worm drive to me
What is a Worm Drive? Can someoen Explain?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
  #32   Spotlight this post!
Unread 04-05-2006, 21:51
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Brakes
A drive system which utilizes worm gears.
Worm gears are nearly impossible to backdrive, so when you're not driving them with your motors, anything powered by a wormgear won't move. Therefore in a drive system, the wheels don't turn when you don't want them to. Worm gears are also terribly inneficient, and you can potentially lose 30% or more of your power in a system using them.
  #33   Spotlight this post!
Unread 04-05-2006, 21:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Brakes
If anyone cares, 772 (Sandwich SS from LaSalle, ON) used a worm drive on each side of their drivetrain (with two small CIMs in total).
The trick with worm gears is that as their efficiency increases, the ability to backdrive them also increases—it's that inefficiency (sliding contact, mostly) that's common in so many of them that permits them to resist being backdriven. Sandwich, if I remember correctly, used custom two-start worms, which were supposed to be reasonably efficient, given the substantial reduction.
  #34   Spotlight this post!
Unread 05-05-2006, 08:58
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Re: Brakes
After our two regionals (and after Jack Jones called us out for being easily turnable) we realized that we needed to get better at holding our position. During the fix-it window after WI we added code to dynamically control the brake mode on the drive motor speed controllers. Using the encoders & code we already had on the robot for our our autonomous driving, we regularly poll our custom circuit for the number of ticks each encoder moved since the last request. If both encoder readings tell us that the wheels are "turning slow" we put all four speed controllers in brake mode. All this happens without the driver's input. When the robot is shooting, the driver puts the the robot into low gear. While this doesn't make us unmovable like 25, it does make us very difficult to move or turn if we're locked up against the ramp wall.
  #35   Spotlight this post!
Unread 06-05-2006, 11:45
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
Re: Brakes
Worm gears are terribly inefficient, that's correct. We used them on our robot, and struggled getting enough power to push and climb the ramp. I don't think we'll be using them next year as they didn't work out as much of an asset this year. But at least we can say we tried! And as far as backdrive, you could still push our robot relativly easily even with the wormgears, they did have some give to them, which kind of defeated the purpose of having them on there in the first place.
www.sabrerobotics.com
Ramp or No Ramp Cyber Punk 234 Rules/Strategy 29 20-02-2006 18:42
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
ok more car stuff greencactus3 Chit-Chat 19 13-11-2005 10:10
What does everyone like to do besides FIRST stuff?? Katie_269 Chit-Chat 45 17-07-2002 17:01
What else do we want? archiver 2000 63 23-06-2002 23:19
