Go to Post All this community stuff is actually pretty fun! :) - JBotAlan [more]
Unread 05-05-2006, 03:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Bending 2" diameter pipe/tubing
Took a look at the HF bender. It's die is for 90 degrees. Looks like a decent unit, but repeatability may be a problem. Took a look at 1 1/2" EMT conduit sweep elbows. Liked em so much I bought a couple (only $5 each). The radius is pretty much perfect, and conduit will be nice because it won't rust and it doesn't cost too much. So, I think that's what I'm going to do. Cut and weld together two 90 degree 1 1/2 inch EMT sweep elbows. Seems like the easiest way out.
BTW, 1 1/2 EMT conduit is closer to 1 3/4 OD if anyone was wondering.
Unread 11-05-2006, 21:27
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You can also buy pre-bent tubing: http://www.woolfaircraft.com/elbow.htm from aircraft & speed/racing shops
[OCCRA]: diameter of the pipes iheartpi OCCRA Q&A 1 28-09-2005 20:26
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
