Go to Post Hyper, I want to marry your robot. - Keys [more]
Unread 06-05-2006, 14:02
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
Impossible to truly to vex holonomic with default code?
Is it possible to do a vex holonomic and control it to its fullest capabilities with the default code?
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Unread 06-05-2006, 18:24
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Re: Impossible to truly to vex holonomic with default code?
Although I have no DIRECT experience in attempting to do this, I am almost totally sure that you cannot make a fully functional holomonic drive system with just the default code. You will probably have to program it in order to achieve any degree of control or to make it do what you want.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 06-05-2006, 23:00
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It's possible, but obnoxious to control. You'd have to set it up so that each of the motors involved was on a different channel on the controller (one on north/south of the left stick, one on east/west of the left stick, one on north/south of the right, and, if a 4th is used, one of the east/west of the right). You'd then have to push each stick appropriately to get it to move in the desired direction. So, if you can compute vectors in your head really quickly, I guess it's possible.
Unread 08-05-2006, 20:40
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Let me just say, programming a holonomic vex bot is very simple, (and I didn't have any programming experience), plus the amount of things you can do with the bot are amazingly higher, so I would HIGHLY suggest buying a programming kit, even though you can build a holonomic vex bot without it.
VEX Robotics Blog
7.20 compiler and 2006 default code pagemauck Programming 12 20-04-2006 13:51
Default Code Idaman323 Programming 5 12-02-2006 17:14
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Default Code and printf WilsonDJ00 Programming 2 22-01-2005 16:39
