Go to Post Pneumonoultramicroscopicsilicovolcanoconiosis. Be careful. - Ether [more]
Unread 07-05-2006, 20:26
Goaliexam Goaliexam is offline
AKA: Max
FRC #1656 (Haverford Robotics)
Goaliexam is a jewel in the roughGoaliexam is a jewel in the roughGoaliexam is a jewel in the rough
Send a message via AIM to Goaliexam Send a message via MSN to Goaliexam
Working with curved surfaces
Does anyone have links to any good tutorials or books concerning working with curved surfaces in Inventor? Let me describe my issue, and maybe someone here can help:
Imagine a 1/4" or 1/8" thick rectangular piece of flexible aluminum (think flashing aluminum), with holes cut out of it in places, and several raised surfaces, and even whole protruded objects. We want this currently "flat" object to be the surface of a cylinder, which we would accomplish in "real life" by bending it around so that the two ends of the rectangle touch, creating a cylinder (without top and bottom surfaces).
I have been trying to model this in Inventor, and have had no success. The measurements and sizes of the cut outs and raised surfaces are extremely important, so extruding into a cylinder object using a tangent work space isn't really the best option.
Anyone have any suggestions for how I could accomplish this?
Unread 08-05-2006, 00:17
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Re: Working with curved surfaces
I don't know if there is anything in any of the later Inventor models but I know I've done work with cylindrical devices one of three ways. First one is using a workplane tangent to the cylinder (what you don't want to use). You can also utilize a workplane traveling through the center of the cylinder. Or you can start off with a square rod where each side is equivelant to the diamter of the cylinder. Then you create your holes and raised surfaces. Then you cut around the raised surfaces in order to create that cylindrical shape (usually easy with just holes kinda complicated with raised surfaces)
2005 2006 2007 Autodesk Inventor Winner
2005 Winning Site & 2006 Winning Site
2007 Winning Site
Unread 08-05-2006, 07:43
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
dont forget about the "extrude from" or "to" command. itll make it easy to extrude from a round object and not have the piece coming out to go through the cylindar in any way, just meet with it. Also, consider the sheet metal. If there isnt a way to bend in circular way in version 10, there should be in version 11 or 12, because i know they are trying to improve sheet metal assemblies
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Unread 08-05-2006, 16:48
Andy A. Andy A. is offline
Getting old
FRC #0095
I've had difficulty using Inventors sheet metal functions to create a cylindrical face. I'm probably missing something, but I would wait a few versions before trying anything really complex with sheet metal. So far, Inventors sheet metal stuff hasn't been the answer to anything.
-Andy A.
Unread 09-05-2006, 14:44
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
-Andy A.
if you bend a sheetmetal piece a full 360º with the bend radius set equal to ((length of sheetmetal piece)/pi), the piece will be bent into a circle, creating a cylinder.
Don't know if this helps, or if it's what you're looking for, but I've had some success with this method.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Week 2: So how's that Field Working? Joe Johnson General Forum 59 19-03-2006 07:08
Camera isn't working Idaman323 Programming 13 15-02-2006 23:18
What I'm Working On Jared Russell Programming 2 18-01-2006 02:34
Who is working on their team site over the summer? Timothy D. Ginn Website Design/Showcase 15 07-06-2005 18:47
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
