Go to Post I've done enough preaching to the choir. Let's carry on changing the culture. - StevenB [more]
Unread 10-05-2006, 12:40
Robots_R_Us Robots_R_Us is offline
Robots_R_Us is an unknown quantity at this point
What NEW Vex Accessories Would You Like TO See?
Sensors, motors, structural parts, WHAT?
Thanks for any suggestions.
RRU
Unread 10-05-2006, 12:46
CraigHickman
Posts: n/a
Re: What NEW Vex Accessories Would You Like TO See?
As for motors, a high speed, low tourque motor would be helpful for rapid action, small space components.
As well as that, a slightly wider selection of wheels would be intersting.
If possible, Mecanum wheels would be very fun to play with. However, I don't know how much the cost would be to make some that small...
Unread 10-05-2006, 12:50
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Besides a smallish higher speed motor, how about a small (7.2V <10A?) speed controller and a small breaker panel to make it easy to drain the battery - er, I mean: build shooters, etc.?
Pete Kieselbach
Unread 10-05-2006, 12:55
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Up the system voltage to 12v. I saw some neat little batteries close to the size of a 7.2v pack except it was 12v with 0.250" tab connectors. This was at Fry's if anyone wants to go see them.
Plus, they should publish the fact that the PWM periods on the VEX controller is the same as on the FRC controller.
The BIGGEST feature i'd like to see on the next rev of the VEX controller is a second TTL serial port so next year's FVC challenge can use the CMUcam. (hear that, FVC admin people? )
Thats all for now.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 10-05-2006, 12:58
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
What diameter? How much would you be willing to pay?
I did some for an EduBot a couple of years ago and for a KitBot last year. I might be able to arrange something if there was sufficient demand. I'll have to check into my cost though.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 10-05-2006, 13:11
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
*Gyroscope - I understand that one can be connected to the microcontroller with some custom wiring and programming, but i think it would be more convenient for the people starting with robotics to have a compatible vex gyroscope.
*Camera - I heard this could also be done with some hardware and software hacking but on a more advanced level. A compatible vex camera (CMU or any other) would really expand the autonomous capabilities of the vex robots.
*sound sensor - for sound activation, like the one in the mindstorms NXT kit.
*Wider variety of motors
*Upgraded remote control, or even some type of operator interface so more advanced users can make their own controls.
*cheaper vex pneumatics kits.
I think the vex kits are great already, but the above accessories will really give it an advantage over the other kits.
Unread 10-05-2006, 13:22
Billfred's Avatar
Billfred Billfred is offline
A camera would be pretty awesome, but you know what I'd like to see? An infrared remote control, like the one that you use (and can never find) on your television. You could then use the Vex system to do things you wouldn't want to whip out the big radio for, like having a robot open up a bottle of root beer* and send it down the conveyor to your couch.
Beyond that, a simple e-stop button to connect to the tether port would be kinda awesome. (The spec is already on the VexLabs site--it's just grounding two pins on the tether port.)
*Hey, you can have the thing open whatever you want--I'm just underage.
Unread 10-05-2006, 13:39
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
What NEW Vex Accessories Would You Like To See?
I second the Gyroscope. A "Vex Gyro" would be sweet, but a generic one would be just as cool.
I would also love to see an simple square shaft to round shaft coupler that would allow an untold number of items to be connected, specifically, I am thinking of potentiometers.
I also agree that a camera would be really nice. Also, lower cost pneumatics would be nice.
Unread 10-05-2006, 14:36
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I would like to see all components the same allen size. And about 14 more allen wrenches in the kit. With high school students, they can stay "found" for about 0.015 sec; the ones we can find are rounded and unusable.
Hi!
Unread 10-05-2006, 15:04
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I like the idea of the gyroscope, but i have done that it's no different than on the full size FRC.
The camera is also a good idea, but all you do to run a standard camera off a vex is use a Y cable for power from one of the digital in/outs and to run a wire from the TTL level TX on the camera to VEX RX port pin closest to the RX label and a wire from the TTL RX on the camera to the VEX TX pin closest to the TX label. Once you do that you can run the camera off Kevin's camera code just follow his instructions on how to use it with the EDU bot.
also i have run Victors speed controllers, hobby servos, accelerometers, gear tooth sensors, and a number of homebrew sensors with the same software as i did on the FRC controller.
I like the idea of a 12v system instead of the 7.2v system, but you would loose the much of your compatibility with standard hobby parts.
The VEX controller already has 2 serial ports the Program port and the TX/RX pins by the inputs.
i like the idea of cheaper vex pneumatics.
I the vex controller should be upgraded to the 18f8722 from the 18f8720 that it's running now.
Eric Haskins KC9JVH
Unread 10-05-2006, 15:24
UnderDark's Avatar
UnderDark UnderDark is offline
Alumni
AKA: Matthew Korzeniowski
UnderDark will become famous soon enough
My current vex wish list:
  • Worm Gears
  • Rack & Pinion Gears
  • Cams
  • IR collision dection sensors
  • springs (shock absorbers, stored energy, etc.)
"My gaming is FIRST!"
-Joe Jagadics
"I am like an all powerful warloard"
-Brian Graham
Unread 10-05-2006, 15:27
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
How about a few more and different types of gears? Bevel Gears, a Rack to use the existing gears as a rack and pinion, Worm gears, and maybe even a planetary gear set up.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Last edited by GeorgeTheEng : 10-05-2006 at 15:27. Reason: I misspelled some things
Unread 10-05-2006, 15:29
AKA: Alex
Wow that would be awesome if you were given a crown gear and drive tape.
You know what i'm thinking...
-Q
Unread 10-05-2006, 16:34
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Definately for more, cooler gears. More sizes of spur gears, worm gear, rack and pinion, bevel, etc
mecanum wheels
More wheel sizes (including wider width wheels)
Removable/replacable/variable wheel treads (for replacing worn ones, adjusting tractions, etc)
3-axis joystick for vex controller
more powerful motors (come on, you know you want em )
More sprocket sizes
Smaller shaft encoders
Unread 10-05-2006, 16:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
not likely, since they would have to make custom screws, or redesign the servos and collars to use larger screws.
I bought a pair of cheezy Sears Craftsman ball hex drivers, number 41660 and 41661, they seem to be a big help. Also the 41973 11/32 nutdriver comes in very handy. Using these real tools instead of those provided with the kit is a big help.
What would you like to see at a regional? Greg Needel Regional Competitions 59 13-07-2004 19:14
Awards in the Offseason: What would you like to see? Erin Rapacki Off-Season Events 14 20-05-2004 20:24
Brunswick Eruption- What matches would you like to see? Wayne C. Off-Season Events 34 12-11-2002 16:30
What Would You Like to See at an Off-Season Regional OZ_341 Off-Season Events 0 17-09-2002 02:01
What Item Would You most Like to See in the Kit of Parts? Ragin_Kage Chit-Chat 15 14-03-2002 19:22
