Go to Post Avoid the impulse to shoot from the hip, and find out the full picture before deciding where you stand. - gblake [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 29-04-2006, 11:53
sw293 sw293 is offline
Former Coach (2005)
AKA: Scott Weingart
FRC #0293 (SPIKE)
sw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of light
paper: Championship OPRs
Thread created automatically to discuss a document in CD-Media.
Championship OPRs by
Team 293
Uncrowned Champions, 2005 Philadelphia Regional
Champions, 2007 Chesapeake Regional
Unread 29-04-2006, 11:54
Former Coach (2005)
AKA: Scott Weingart
FRC #0293 (SPIKE)
Re: paper: Championship OPRs
These are the real Championship OPRs. The ones being passed out at Championship were from regionals and this was being done against my wishes.
Team 293
Unread 10-05-2006, 16:28
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Thank you for these. I did not know about the incorrect OPRs at championships, that really is too bad that a team would do that. They might not of realized that robots can change drastically in performance since regionals.
Only thing: Some people don't know what OPRs are in the first place so it might not hurt to either put a header on the files or in your origin whitepaper post.
Thank you for generating these again!
EDIT: For those who haven't seen the original white paper about OPRs, it stands for Offensive Power Rating. It is a mathematical way to express team's progress and, obviously, offensive power. More information about OPRs can be found at this forum thread.
Unread 10-05-2006, 16:42
Back after 4 years off
FRC #5279
What do negative points indicate?
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-05-2006, 17:29
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Likely that the team had a tendency to draw penalties. The definition of OPR as I understand it is "the amount of points a robot contributed to their alliance on average". So if your team contributed negative points, then you were either such a liability that you hurt your alliance partner's scoring abilities, or you drew a lot of penalties.
As I understand it, you have to actively be an impediment to scoring (simply not scoring is not enough) in order to get negative points.
Another possibility is that the presence of your robot depressed scores on both sides. A dumper could conceivably do this. Collecting all the balls that would otherwise be shot into the high goal might reduce scores, although sw293 may want to confirm this.
Unread 01-06-2006, 22:19
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Wow! - It's hard to believe anyone had a lower Curie division OPR than us.
Next year.....
Blake
paper: 2006 Niagara FIRST Public Championship Scouting Database Karthik Scouting 17 20-04-2006 19:26
White Paper Discuss: Continuous Improvement - 2005 Championship Forum Presp Chris Fultz Extra Discussion 0 25-04-2005 12:55
White Paper Discuss: Karthik's Championship Event Data CD47-Bot Extra Discussion 20 13-04-2004 08:17
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Championship Qualification - Constructive Criticism Andy Baker Championship Event 7 29-10-2003 16:48
