Go to Post Ask the right questions and you can get the right answers. - Chief Hedgehog [more]
Unread 11-05-2006, 10:55
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: What NEW Vex Accessories Would You Like TO See?
Originally Posted by SizzelChest330
I cant believe nobody's said this...
NEW CHAIN!
Seriously. its not very reliable. too much skipping. not being able to gear for speed very well.
I really would like to see a much higher speed/smaller and more torquey motor as well
Worm gears. for sure.
I'm liking this less expensive pneumatics idea. maybe smaller cylinders as well? (2 speed trannys?)
If used properly, the Vex chain is very reliable, plenty strong enough, and won't skip teeth on the sprockets. It all depends on how you use it. You need to have the chain properly tensioned, because if the chain is too loose it will skip, and if it is too tight it will snap. Between those two extremes the chain in the Vex kits will perform well and can lift several pounds of Vex parts easily.
The pneumatics kits can't really get that much smaller, as they are only 10 mm bore to start with.
And if people really want different pneumatic cylinders, why not just buy them directly from companied like Bimba or SMC? Bimba sells 5/16" bore single-stroke and double-stroke cylinders for $10-20 each, with each additional inch of stroke costing $1.30.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-05-2006, 18:41
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
I'd really like to see quadrature encoders, I can't imagine them adding to the cost that much, just add another photo interrupter, and have Intelitek implement the quadrature encoder the same way they did the one included in the kit, except for counting down when going in the opposite direction.
I also agree with the addition of pots, you could make your own "servo" except gear it however you want!
Unread 12-05-2006, 02:18
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
I felt that the EDU chain works a lot better than the VEX chain. maybe bring back that chain to use in the kits. Also, the drive screws need to be tougher, or the allen wrench for them needs to be better as only those screws seem to strip really freaken easily, even without torquing the screw or tightening. A nice assesory to add would be a worm gear configuration. It would be great for making an arm with a lot of weight.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 13-05-2006, 16:53
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
I also think some sort of all thread should be added so that you can splice the "beams" togather (beams). I found i ran out of these long beam rather fast so splicing a few little ones would be a quick fix before buying a hardware kit or something else.
Unread 13-05-2006, 19:34
nonother's Avatar
nonother nonother is offline
Founder
FTC #3053 (Occam's Engineers)
nonother will become famous soon enoughnonother will become famous soon enough
If you mean connecting the beams together then just use the 8-32 Coupler they sell on the page you linked to.
Unread 13-05-2006, 23:57
AKA: Sam Couch
Yeah that is exactly what i meant... i didn't even know they had those...
What would you like to see at a regional? Greg Needel Regional Competitions 59 13-07-2004 19:14
Awards in the Offseason: What would you like to see? Erin Rapacki Off-Season Events 14 20-05-2004 20:24
Brunswick Eruption- What matches would you like to see? Wayne C. Off-Season Events 34 12-11-2002 16:30
What Would You Like to See at an Off-Season Regional OZ_341 Off-Season Events 0 17-09-2002 02:01
What Item Would You most Like to See in the Kit of Parts? Ragin_Kage Chit-Chat 15 14-03-2002 19:22
