Go to Post Iteration is a necessary but not sufficient criteria to being a powerhouse team. - Chris is me [more]
Unread 20-04-2006, 08:09
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Pic: Easy to make mecanums..
Do you have some cad files? If so, you should share them with us; I'm sure a lot of people would love to make their own.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 20-04-2006, 11:06
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
we'll whitepapre and upload it once we get all the problems worked out.. we've found a few, we're in the process of fixing them.
Unread 24-04-2006, 22:35
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Tatsu
but a mill is nice =p.
Sweet! Very nice process.
What, if any, bearings are used on the shafts that hold the lab stoppers?
I'd also be interested in hearing more about the durability of the stoppers.
Don
Unread 25-04-2006, 12:36
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Don
As of now the lab stops are on bolts. This was just for the picture
We are in the process of ordering a bunch of .250 ID 1" length bushings to put in all the rollers. They will then run on a ground steel shaft that is pressed into the wheel housing, with E-rings on the edges to keep the rollers from sliding off. We know that the wheels are slightly fragile with the rollers outside the wheel like that, and the steel roller shafts would be prone to bending. But like most robots, we plan to have our wheels well protected from all sides. The wheels can take huge forces radially, because if pushed hard enough the rollers will compress and the wheel bottoms out against the aluminum housing. This takes about 150-200 lbs per wheel to do.
A side note, efficiency is not reduced by weight on the wheel (other than more friction in the bushigns) because there is enough clearance on the sides of the rollers to allow for expansion due to weight compression. Also, these wheels get very good traction because the rollers are made of gum rubber. This means that all the rollers will have to be replaced every regional, but at 25 cents a piece from mcmaster, I dont think that will be a problem.
Our goal from this is basically to have an agile mecanum robot with lots of traction and pushing power, something not common with omni-directional robots. Look forward to designs for ball shifting transmission for each wheel...
Unread 25-04-2006, 12:51
AKA: Mongo
For some reason I'm contradicting myself, I've designed a set of these before, but I think I might have done them wrong; what angle are the rollers supposed to be offset to the hubs?
Unread 25-04-2006, 14:22
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Nearly any offset will work in theory, but 45* is most efficient.
--Madison--
...down at the Ozdust!
Unread 25-04-2006, 21:31
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Its not that 45* is most efficient. It is that 45* results in the max speed to the side is equally to the max speed forward. They are actually less efficient than say 30* because the rollers need to turn faster when moving in a direction other than forward. Of course 30* also means that the max side speed is lower than the max forward speed and the pushing power is greater.
Unread 25-04-2006, 21:33
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
A little birdy told me that free mecanums are always the easiest, but if you don't win them these are pretty darn cool!
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 25-04-2006, 23:20
Madison's Avatar
FRC #0488 (Xbot)
By 'most efficient,' I meant simply that a 45* offset allows for the fastest perpendicular drive speed. It's true that you can optimize the offset angle to better suit the conditions under which the drive will operate.
--Madison--
Unread 08-05-2006, 20:29
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Question:
Most mecanum wheels have the rollers at a 45* angle on 2 axes (I think you all know what I mean, at least, I hope it's clear: the rollers are at a 45* angle to the wheel and then angled upwards, correct?)
Is this necessary, is it simply for increased traction, or could one theoretically design a mecanum wheel more in the style of an omni wheel, simply rotating the rollers to a 45* angle instead of a 90* angle?
www.metalmoose.com
Unread 08-05-2006, 20:53
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Yeah, take a look at this report (where i got most of my Mecanum information from) specifically the image on the first page titled the conventional Mecanum wheel. I think that is what you are talking about and although not as cool looking as the others, probably the easiest Mecanum to build if you don't have a CNC mill or, mill master and don't want each wheel to be a multi piece wheel.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 12-05-2006, 11:01
Jack-Of-All-Trades
Is the oblong roller necessary as well, or could one do something more along the lines of an AM trick wheel with the roller at a 45* angle?
www.metalmoose.com
Unread 12-05-2006, 12:22
The shape of the angled roller is intended to make the overall profile of the wheel a smooth circle. If that's not done, the wheel will be somewhat "bouncy" in operation, and it won't have consistent traction as it turns. If the inconsistency is severe enough, it will be difficult to maintain a desired direction of travel.
Unread 21-06-2006, 22:47
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
The finished mecanum! (Sorry about the glare)
A comparison with the spares.
Much lighter now
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 24-06-2006, 19:53
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Excellent job 1072 very nice machining process. I also love what you have done on being able to lighten the wheels. I like the fact that 1072 makes most of the stuff they design and has some great initiative about things like that. Finally, amazing pictures.
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
How to pass your inspection at Nationals, the EASY way Matt Reiland Championship Event 0 04-04-2003 18:39
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
5 points I make..(and a little excess) archiver 1999 7 23-06-2002 22:18
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
